i3wm xenial-i3 introduction -- mate terminal & battery monitor
Information
Greetings,
The purpose of this blog post is to introduce the  i3  window manager , as well the ayufan xenial-i3 pine community image.  I am a completely sold out i3wm convert ;  never going back--  i3 for me !
The i3 Window Manager Tutorials and Introductory Videos
       Tutorial Introduction from i3wm.org
       On-line Tutorial Video Part (1/3)
       On-line Tutorial Video Part (2/3)
       On-line Tutorial Video Part (3/3)
       i3wm User's Guide from i3wm.org
The above tutorials are well worth the time and effort, are fast--and fun--and will get you up and running with this super tiling windows manager on your new Pinebook !
I am currently running the 0.4.16 xenial-i3 on my Pinebook with the mate-terminal;  you may quickly want to replace the terminal on i3 because the font is so small, and because the dafault is a minimalist terminal;  the mate-terminal is fully equipped and ready to roll with nice fonts and a rich tool-bar:
       sudo apt install mate-terminal
Below I am going to show the interface of this excellent tiling window manager, and provide a batt_status.sh script which can be used to monitor your battery status more effectively than the i3 status bar.
The pic above is my first ( #1 ) virtual work space;  I have three terminals open--  it is clearly obvious why its called a tiling window manager.  Not to worry , floating windows are configurable too!
I'm doing some Python work in the left terminal, and in the right terminal I'm displaying the code ( also included here ) for displaying the battery status in a loop-- running in the bottom right-hand terminal of work-space #1.
I removed the battery block of my  .i3status.conf  file.  The script below ( batt_status.sh ) goes in your ~/bin/  folder and runs in a forever loop in a small terminal showing the battery current status ( charging | discharging ) the voltage in micro volts, and the percent capacity.
Note:  the battery status bar component is broken on this image.  The script below is a simple elegant solution for battery monitoring in a tiling terminal environment.
batt_status.sh
#!/bin/bash     while [ 1 == 1 ] do    echo " capacity : " `cat /sys/class/power_supply/battery/capacity`    echo "  voltage : " `cat /sys/class/power_supply/battery/voltage_now`    echo "   status : " `cat /sys/class/power_supply/battery/status`    sleep 7 done
Note:  the little quote-like characters above ARE NOT quotes-- they are back-ticks;  the little character under the tilde ( to the left of the 1 key on most keyboards ).
Remember,  i3  is a tiling window manager NOT an OS;  the operating system under the covers is ubuntu which is a debian derivative.
Enjoy !
Shy
Wow, thank you a lot - it is amazingly fast, I'll not switch back to mate Smile
But looks like closed lid is not send notebook to sleep, yes?
hi , a quick warning;   I never close my lid and put the computer to sleep ( not ever ).
The warning is that if you forget you did that ( and sooner or later you will ) the battery will run flat !  and when it does, it will NOT recharge without going through some very costly and troublesome hoops.  ( words to the wise )
Always shutdown the system ...  on the i3 window manager the best way is in a terminal with :
       sudo poweroff
Shy
So, I did some configuration to fix battery indicator issue.
First of all install i3blocks via apt-get and config i3 file to use i3blocks as main bar.
After this, open:
pine64@pinebook:~$ vim ./.config/i3/i3blocks.conf
And edit battery section to this one:
[battery] label=BAT command=tail "/sys/class/power_supply/battery/capacity" #label=⚡ #instance=1 interval=30
For sound you can do the same:
[volume] label=VOL #label=♪ instance=Master #instance=PCM interval=1 signal=10 command=/usr/share/i3blocks/volume 5 pulse
For anyone, I will strongly recommend to spend few time for videos in the start of the tread - they are easy and very helpful for i3 noobs like i'm.
I have not fix an issue with closed lid yet and still can't find a terminal command to edit brightness value, if someone know it, please share it
  [SOLVED] How to poweroff PBP from Linux terminal? mx43 1 6,483 03-21-2020, 12:49 PM
  Display battery charge value with LXDE and lxpanel wlad 1 8,406 12-04-2019, 03:36 AM
Last Post: pnts-se
  Armbian - Xenial Desktop (Pinebook) pineadmin 83 179,183 07-17-2019, 01:22 PM
Last Post: catsmile
  Improve the life of your Pinebook battery by setting charger's voltage limits wlad 0 4,533 06-11-2019, 02:27 PM
Last Post: wlad
  Adding coherent_pool to boot.cmd on Xenial Mate by Ayufan causes boot loop k_mp 0 3,642 06-11-2019, 01:36 PM
Last Post: k_mp
  How can I reliably get battery status on pinebook tillea 5 15,710 06-11-2019, 10:10 AM
Last Post: wlad
  Problems putting Ubuntu (Xenial Mate) on my replacement eMMC. frank-zappa 11 25,022 05-01-2019, 12:09 PM
Last Post: frank-zappa
  Battery Status in Bionic X-Istence 3 8,725 03-11-2019, 03:52 PM
Last Post: soupbowl
  .bashrc to show battery percentage at prompt e-minguez 1 5,502 03-05-2019, 07:03 PM
Last Post: PatrickM
Information How to set the Power Off key binding in i3wm for the Pinebook MarkHaysHarris777 4 12,808 12-25-2018, 05:57 AM
Last Post: binholz
