Newbie question - should a Rock64 with no mmc card still output some video ?
My unit arrived this week.  Powering it on doesn't elicit any response on either of my monitors.    The green, white and red LEDs remain on and stable.
Is this normal ?
When the unit is powered on, it will first look for the valid boot image in either SD or eMMC to load. What did you install on your SD card? Android? Debian Jessie? Xenial?
(08-18-2017, 02:23 PM)sgk Wrote: My unit arrived this week.  Powering it on doesn't elicit any response on either of my monitors.    The green, white and red LEDs remain on and stable.
Is this normal ?
Yes, as with most SBC's, there is no video output without a bootable image either on EMMC or SDC.
Good luck!
Is this normal ?
Good luck!
There is no firmware at all;  nothing!  no bios, no eufi, nothing;   everything is in the image and that lives on the SD or the eMMC;   eventually we will have uboot on the on-board SPI flash, but not yet....
Fwiw, I had this problem on my main monitor (no signal). I tried every combination of mmc / sdcard with no luck but when i plugged it into my 4k TV I had no problem at all. Maybe it was trying to output 4k video which isn't supported in my monitor (over hdmi at least). EDID broken?
(08-23-2017, 02:16 PM)Bloop Wrote: Fwiw, I had this problem on my main monitor (no signal). I tried every combination of mmc / sdcard with no luck but when i plugged it into my 4k TV I had no problem at all. Maybe it was trying to output 4k video which isn't supported in my monitor (over hdmi at least). EDID broken?
I just installed a ran Debian Stretch on my Rock64 last night.  It happily output console text through HDMI to my non-4K computer monitor and so my experience is different from yours.
Is this normal ?
Hi
I followed the guide on wiki for booting android on emmc:
http://wiki.pine64.org/index.php/ROCK64_...se_version
http://files.pine64.org/doc/rock64/guide...o_eMMC.pdf
Please note that before flashing firmware, there won't be any signal coming out from hdmi port.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 5,159 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 24,721 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 14,980 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 16,225 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,001 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 8,668 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 9,793 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 8,990 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,264 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 4,356 10-07-2022, 07:50 PM
Last Post: rookie_267
