Read if you experience issues with screen flickering
Edit (15/10/2017) Newest pre-release image allows you to set display mode to fix flickering. Check ayufan's git
It seems that the newest batch (as of 04/08/2017) of Pinebooks shipped with an older Ubuntu image based on 3.10.105-bsp-1.2-ayufan-59 (you can check if your's is running this version by typing uname -a in terminal).
Some Pinebook's experience screen flickering while running this kernel version, which is solved by upgrading to newest release version.
To update your installation navitgate to /usr/local/sbin and run the following update scripts:
sudo ./pine64_update_kernel.sh 0.6.2
sudo ./pine64_update_uboot.sh 0.6.2
sudo ./pine64_update_package.sh 0.6.2
Run all three and then reboot.
For those feeling adventures and who want to try out pre-release images with additional features but also bugs and broken settings please see ayufan's git releases with instructions on how to update.
Thank You, This information solved the screen flicker on my new Pinebook 14.  Now I just need to do some research on the low sound volume.
(08-05-2017, 12:50 AM)skdrowe Wrote: Thank You, This information solved the screen flicker on my new Pinebook 14.  Now I just need to do some research on the low sound volume.
in alsamixer, settings at the very end (jut hold down right arrow key) called 'speaker volume' will allow you to increase the volume.
Thank You again.  Audio is much improved and usable.
(08-04-2017, 09:02 AM)This was driving Luke Wrote: It seems that the newest batch (as of 04/08/2017) of Pinebooks shipped with an older Ubuntu image based on 3.10.105-bsp-1.2-ayufan-59 (you can check if your's is running this version by typing uname -a in terminal).
Thank you Luke! The flickering was driving me nuts, but this has fixed it :-)
(08-04-2017, 09:02 AM)Luke Wrote: It seems that the newest batch (as of 04/08/2017) of Pinebooks shipped with an older Ubuntu image based on 3.10.105-bsp-1.2-ayufan-59 (you can check if your's is running this version by typing uname -a in terminal).
I've got annoying flickers on the screen of my new Pinebook. I noticed them right after I had turned on my Pinebook :/ So, then I tried to update as it is recommended above but that didn't fix that issue. Any suggestions?
PS At least, I've managed to increase the sound
Strange. take a short vid of the flickering or describe in more detail?
[quote pid='30642' dateline='1502874892']
[quote pid='30599' dateline='1502822263']
[/quote]
[/quote]
Sure, here it is (480p):
atr.mbl
Clearly different to what most users experience - do join in the IRC will be easier to troubleshoot.
(08-16-2017, 03:14 PM)Luke Wrote: Clearly different to what most users experience - do join in the IRC will be easier to troubleshoot.
I think the noise is pretty much the same like the one reported here:
https://forum.pine64.org/showthread.php?tid=4843
So I was hoping that is a common problem that can be fixed very  easy :/
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 5,317 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Screen halo? caps 7 16,052 03-09-2021, 11:56 AM
Last Post: nasask8r
  Pinebook 14" smashed screen. frank-zappa 4 13,289 10-18-2020, 09:24 AM
  Screen staying dark. ocschwar 2 7,815 07-18-2020, 04:54 PM
Last Post: ocschwar
  New user - couple of issues sliberty 2 5,754 05-22-2019, 05:36 PM
Last Post: phuzy
  Pinebook Issues DannyJack 6 11,982 05-18-2019, 09:54 AM
Last Post: Surehand53
  Screen resolution heywire 5 11,425 04-03-2019, 01:42 PM
Last Post: bigCamel
  DCOP communications error (Welcome screen) jschall 2 5,839 11-17-2018, 02:33 PM
Last Post: jschall
  How to adjust screen brightness? jschall 4 10,528 11-15-2018, 12:38 PM
Last Post: jschall
  1080p mainline kernel issues e-minguez 2 5,562 11-14-2018, 02:54 PM
Last Post: e-minguez
