Actual schematics for the pinebook?
On the pinebook resources page:
https://www.pine64.org/?page_id=5734
There are schematics listed. However, these schematics don't seem to match the actual hardware, and thus are quite useless.
Are the actual schematics known?
(08-04-2017, 08:53 AM)daid Wrote: On the pinebook resources page:
I have asked TLLim about updating the schematics;  will post when I hear back.
Most of the main board schematics are correct ( and useful for quite a lot ).
The small board schematics are for the x86 version Oakbook;   they are good for some things too, but the PCIe lane is obviously not there and the chip is not mounted.
Spoke with tllim this morning;  says the schematics are 100% correct; ofc the small board schematic shows the PCIE chip which is not mounted on the Pinebook, otherwise the rest of the schematic can be relied on.
If you have specific questions about the schematic, please post them and we'll try to get answers for you.
Dodgy
(08-05-2017, 01:48 AM)MarkHaysHarris777 Wrote: Spoke with tllim this morning;  says the schematics are 100% correct; ofc the small board schematic shows the PCIE chip which is not mounted on the Pinebook, otherwise the rest of the schematic can be relied on.
Dodgy
Maybe it's me not reading it right, but I see a camera connected with CSI, while linux lists it as USB connected. And then the PCEI chip. That combined threw us on the path that these schematics couldn't be the 100% right ones. Also the first page of the schematics list things that aren't there (2nd camera, 2G modem)
Dodgy
It is a little difficult to read;  I must agree.  The way it was explained to me is that the design house takes the reference schematic and just  adds|deletes  stuff from it as they work up the production boards|schematics.  This makes it very easy to track changes;  however, it leaves stuff on the schematic often like the empty camera CSI block.  So, the way to read the camera CSI block on page 10 is that there are no connections to the A64 CSI port-- and this is in fact true--  there is no CSI connector on the board !   ... but, the A64 CSI port does exist !
The functional camera is in fact a usb device and its connections are located on the display cable;  as you already figured out from the disassembly.  Mine shows as Silicon Motion Inc, formerly Feiya Technology Corp 300K pixel camera device 004 id: 090c:037c     There is no rear facing camera (CSI) and the schematic page 10 indicates that the port is empty;  this is a little sloppy, but is regardless 100% correct.
Our tech in Germany has checked the schematic very carefully ( talked to him tonight ) and he concurs with tllim that the schematic is 100% correct with the single exception that the small board schematic does not have the PCIe lane chip mounted on the board ( again, a carry-over from the reference schematic from Oakbook ). He further states that "so far" he has found no bugs in the schematic between the docs on-line and the actual hardware. ( I trust this guy implicitly )
I hope this answers your questions;  please feel secure in the docs as they stand, and also please don't hesitate to ask any further questions that come up;  I may not know, but I'll get you an answer one way or the other.
Note:  while the usb camera "connections" are on the schematic , the usb camera is NOT on the schematic;  they had planned on using the CSI camera in the beginning, but the cables turned out to be not long enough;  hence, the usb camera add-on with the display cable.
Wink
(08-05-2017, 09:45 AM)daid Wrote: Maybe it's me not reading it right, but I see a camera connected with CSI, while linux lists it as USB connected. And then the PCEI chip. That combined threw us on the path that these schematics couldn't be the 100% right ones. Also the first page of the schematics list things that aren't there (2nd camera, 2G modem)
Yeah, the reference PCEI chip from the daughter-board is simply a leftover from the schematic coming from another project which does use it. The only real mistake I know of so far is the block diagram on the first page of the main schematic, which as you mentioned is listing the two cameras on PCSI, and the 2G modem, plus a capacitive touch screen... probably just leftovers from the design stage, and never implemented. Another thing to look out for is the 'NC' against component listings... meaning it's not populated, but the board should still have provision for that part.
If you work from the presumption that the main schematic is accurate, you can also rule out the PCIE when you look at page 9, as all of the 'PCIE' pins from the daughter board are grounded, and two are actually used for the USB hub Wink
  Running Pinebook (non-Pro) without battery? guidol 0 3,082 11-09-2025, 04:19 AM
Last Post: guidol
  Anyone selling a Pinebook ams 2 12,274 09-08-2025, 09:26 AM
Last Post: ams
  Giving away a Pinebook Pro for free (with a broken hinge) tuxifan 4 7,186 09-01-2025, 12:24 AM
Last Post: alchemist
  pinebook 1080p power/barrel connector/cable cel 0 2,901 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 4,323 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 4,245 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 5,906 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 8,835 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 6,814 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 7,932 01-13-2021, 11:03 AM
Last Post: barray
