06-12-2017, 07:58 AM
Are there any plans on introducing a larger LCD touchscreen? I used the 7 inch LCD touchscreen with Linux and decided that it was too small for me.
Larger LCD touchscreen
06-12-2017, 11:44 AM
Maybe you can use the screens they were using in the laptops. They are edp but you there are schematics you can make edp2dsi converter.
06-12-2017, 02:26 PM
Not out of the box, the LCD RGB interface is multiplexed with the RGMII interface for Gigabit Ethernet, so you can't use the same Analogix bridge...
Come have a chat in the Pine IRC channel >>
06-13-2017, 03:16 AM
So do you mean some of the high speed ports shared with gigabit Ethernet due to that it is not possible to use the bridge? |
| Search Compatible 10.1" touchscreen | alfredo78 | 0 | 3,701 |
07-06-2018, 03:48 AM Last Post: alfredo78 |
| Touchscreen display mods | atomicSoC | 2 | 10,786 |
08-26-2016, 05:44 PM Last Post: pfeerick |
| Touchscreen support? | NoahJ | 12 | 26,011 |
07-09-2016, 12:01 PM Last Post: yodermk |
| Large multi touch touchscreen for P64? | vedranius | 5 | 12,484 |
05-20-2016, 09:43 PM Last Post: tllim |
Raspberry Pi 7" Touchscreen Display not work? | Paara | 2 | 8,751 |
05-05-2016, 08:47 AM Last Post: tllim |
| Touchscreen monitor to use | lefartenshisten | 1 | 5,732 |
04-30-2016, 10:47 PM Last Post: MichaelMeissner |
| Touchscreen Alternatives | NoahJ | 10 | 24,599 |
03-10-2016, 04:35 AM Last Post: Fr0z7y |
| Petition thread for screen larger than 7inch | MostHated | 4 | 9,602 |
03-02-2016, 03:40 PM Last Post: MostHated |
