SOPINE A64 DRAM init error
Hi!
I received the SOPINE A64 with motherboard.
The problem is that the initializing SDRAM Fail
The log from serial console:
HELLO! BOOT0 is starting! boot0 commit : 045061a8bb2580cb3fa02e301f52a015040c158f   boot0 version : 4.0.0 set pll start set pll end rtc[0] value = 0x00000000 rtc[1] value = 0x00000000 rtc[2] value = 0x00000000 rtc[3] value = 0x00000000 rtc[4] value = 0x00000000 rtc[5] value = 0x00000000 DRAM driver version: V1.1 rsb_send_initseq: rsb clk 400Khz -> 3Mhz PMU: AXP81X ddr voltage = 1500 mv DRAM Type = 3 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3) DRAM clk = 672 MHz DRAM zq value: 003b3bbb DRAM error status 0  DRAM init error! initializing SDRAM Fail.
It's a hardware problem or can I solve it?
Thank you!
Mod edit: wrapped terminal output in code tags - heaps with long code, and also prevents 'smilies' randomly popping up
(05-29-2017, 02:49 AM)vicb Wrote: Hi!
set pll start
set pll end
PMU: AXP81X
DRAM Type = 3 (2Big GrinDR2,3Big GrinDR3,6:LPDDR2,7:LPDDR3)
DRAM clk = 672 MHz
DRAM error status 0
DRAM init error!
Thank you!
Looking like you run the PINE A64 OS build on SoPine module. The SDRAM fail is due to SoPine using LPDDR3 system memory. Please uses the OS build that targets for SoPines and should able to boot up properly.
Thank you!
  Tow-boot on Sopine module? poVoq 2 5,242 04-05-2023, 12:48 PM
Last Post: poVoq
  Benchmarking the SOPINE Modules on the Clusterboard clusterDude 4 11,099 08-20-2020, 12:56 PM
Last Post: xmixahlx
  Sopine Fedora 32 on clusterboard w/networking revoman 0 5,154 05-20-2020, 01:23 AM
Last Post: revoman
  SOPINE LTS Availability and Plan aldrich@tulip.co 0 4,377 05-14-2020, 10:00 AM
Last Post: aldrich@tulip.co
  SoPine eMMC compatibility Terra854 4 12,637 02-20-2020, 07:52 PM
Last Post: mcrognale
  Sopine baseboard CSI port camera not work olivaw 2 6,881 02-20-2019, 09:50 AM
Last Post: maya.b
  Is it Sopine, SOPINE, SOPine or SoPine? Pine 2 8,495 01-07-2019, 08:37 AM
Last Post: Pine
  +SOPINE baseboard datasheet is different gamelaster 3 9,941 09-09-2018, 05:08 PM
  How to control the SOPINE UART and SPI pins as GPIO? Pine 1 5,809 08-22-2018, 10:15 AM
Last Post: martinayotte
  Two of our sopine's only register 1GB RAM paradise 3 8,333 08-09-2018, 08:35 AM
Last Post: paradise
