RemixOS 2.0 on Pine64+2G + WiFi Module - No signal
Sad
I've a Pine64+ 2GB, with RemixOS on board. It works well, but the WiFi Module does not receive any signal. I've inserted correctly the uFL connector to the WiFi Module, but nothing happend.
I have a Router on 2.4GHz, with a distance of 15mt. My Smartphone can reach the signal with quite-full power, but the Pine64 not.
I've bought another antenna with uFL connector:
2.4GHz Mini Flexible WiFi Antenna with uFL Connector
but I cannot get any signal. The only signal I can reach is the AP smartphone closer to about 1mt.
Somebody can help me?
(05-17-2017, 05:40 AM)klode Wrote: Hi,
Have you tried a different channel on your router ? I suggest trying channels 6-11.
you might could try taking the wifi module off and then back on a few times
  Which Wifi Dongle? pfunk237 16 39,927 07-08-2017, 04:16 PM
Last Post: Luke
  Love RemixOS but 1 issue elpipetuanis 2 7,360 04-20-2017, 08:10 AM
Last Post: klode
  How do you auto-start apps in RemixOS? utdrmac 3 12,255 02-13-2017, 05:18 PM
Last Post: szollinger
  RemixOS Root modsbyus 7 18,910 12-19-2016, 07:51 PM
Last Post: Toriless
Exclamation Adding of WiFi/BT board causing reboots mmb 7 19,174 07-16-2016, 05:06 AM
Last Post: Toriless
  Pine64 With HD screen? pine771 3 8,054 06-11-2016, 10:18 AM
Last Post: Wesleypjones
  Pine64 Remote and Remix VAAviator 3 7,170 06-09-2016, 07:25 PM
  RemixOS - slow download speed in OS mkyb14 9 19,925 05-16-2016, 04:53 AM
Last Post: Alex_TNT
  Overlapping partitions on latest RemixOS image EricL 7 14,941 05-01-2016, 09:01 PM
  Any Android App to control RemixOS ? afr0 1 4,873 04-20-2016, 04:22 PM
Last Post: fneves
