GPIO, SPI and I2C C++ Lib
Star
Hi to everyone! I'm a CS teacher and for some time I playing with my Pine64+. Last week, I built a C++ library (in object oriented paradigm) for manage GPIO, I2C and SPI.
https://github.com/databit/Pine64-CPP
This lib is based on the work of Eric Ptak <trouch@trouch.com>, Stefan Mavrodiev <support@olimex.com> and Kamil Trzcinski <ayufan@ayufan.eu>
I hope this library can be of help to you!
Send me yours comments and eventual bugs.
Master's degree in Computer Science. Teacher technical-practical computering at #Miur. Research Interests: Web tecnologies and programming cross-platform
https://twitter.com/Dat4BIT
http://www.danielecontarino.it
Nice work ;-)
Thanks for taking the time to post this to the forums too...
I will have a closer look over the weekend...
(04-20-2017, 04:00 PM)databit Wrote: Hi to everyone! I'm a CS teacher and for some time I playing with my Pine64+. Last week, I built a C++ library (in object oriented paradigm) for manage GPIO, I2C and SPI.
Thanks so much, really 'preciate the effort;  will take a look closer this weekend, thanks for posting !
Shy
I'm glad you like it!! Smile
Very cool!  Does anyone know exactly how many IO lines you can use as general purpose IO on the PINE64??
My sons science fair project needs 192 IO lines (96 in, 96 out) and we are trying to figure out how many Pine's to buy, the IO is straight digital signals going to high speed DAC and ADC's
Thanks!
Maybe u can use io expansion ic's and control them via spi or i2c
Sent from my Moto G (4) using Tapatalk
Good job with lt he library and so far it's have be n fun still working to make it work with some devices that I have but works good thanks @databit
By. Zoidiano0!
Installed:
LAMP: Linux , Apache2.4 , Mariadb, phpMyadmin, PHP5
Java 8 arm by oracle
Netbeans 8.1
chromium (uses way toooo much Ram)
Pine64 Head Unit Project.!
I've grabbed the files from github and the sample works fine.  It is intersting that there seems to be some similarities to what Derek Molloy had done for the Raspberry Pi but I do like the use of "/dev/gpiomem" to avoid having to be root when accessing the gpio pins.  Is there a reason why there are still references for the Raspberry Pi hardware "BCM2708" instead of the Pine64 harware?
Are there any SPI and i2c examples for this?
Thanks.
Just in case someone is still following this old post, I created a new thread regarding segmentation faults I am getting while trying to use the Pine64-cpp library.
https://forum.pine64.org/showthread.php?tid=7126
Thanks!
  RPi.GPIO python module for Pine A64/A64+ aquilegia 99 220,721 12-15-2025, 07:42 AM
Last Post: freidepiter
  fm transmitter with gpio weasel18 2 8,234 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 6,054 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 17,969 06-07-2019, 12:37 AM
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 18,267 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 49,022 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 22,672 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 34,328 08-17-2017, 01:21 PM
Last Post: martinayotte
  GPIO fiq capability joseph 3 9,921 11-10-2016, 06:07 PM
Last Post: joseph
  RPI2-GPIO mus1c 6 15,556 09-22-2016, 05:28 AM
Last Post: mus1c
