No Ethernet on Andriod
Does the Android image support Ethernet?  I only see wifi under settings.
(03-27-2017, 12:59 PM)rvalecruz Wrote: Does the Android image support Ethernet?  I only see wifi under settings.
There is Ethernet setting under setup.
Mine doesn't have it either.
How can I setup Ethernet, anybody?
(04-13-2017, 02:16 PM)dqvsra Wrote: How can I setup Ethernet, anybody?
  Specifically which image are you using? Since Android is based around phones it is primarily looking for WiFi connection. You have to dig a little deeper in the menu's to find Ethernet setup, but it is there.
What happens when you connect via ethernet? For me, plugging in and waiting at most a couple minutes is all I have to do.
Sent from my Moto G (5) Plus using Tapatalk
  Possible to simultaneously connect to ethernet & wi-fi? wahdooyah 3 7,628 01-26-2018, 06:57 PM
Last Post: dkryder
  2nd ethernet in PINE64 with android daniele 2 6,939 12-07-2017, 05:09 AM
Last Post: daniele
  My Hacky ethernet fix anarchyuk 21 47,180 11-20-2016, 12:01 PM
Last Post: waldo
  Lost Ethernet hatman28 13 28,748 11-10-2016, 09:05 PM
Last Post: pfeerick
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 37,143 10-29-2016, 04:31 AM
Last Post: joe
  Android Ethernet Problem a5467021 11 27,395 08-01-2016, 07:41 PM
Last Post: a5467021
  Can we force the ethernet link to 100mbps? moondark 10 23,763 07-26-2016, 10:56 AM
Last Post: kermitas
  question about burning Andriod/Remix images--Phoenix image first? bigben 4 11,487 07-19-2016, 04:28 PM
Last Post: Ghost
  Android Issues; 4K, Ethernet, Plex kikootwo 6 12,004 07-10-2016, 12:23 AM
Last Post: yusijs
  Android and Ethernet W1SPY 54 107,990 07-07-2016, 01:48 AM
Last Post: Absum
