question about burning Andriod/Remix images--Phoenix image first?
Newbie here and sorry for this stupid question.
I'm trying to burn sd card for my Pine64 2GB board, using Phoenix card utility V310 20130618. if I select any android or remix os image form the tool, an error window pop and complain there's "No script, try a new version image".
Should I burn the Phoenix image first with this Phoenix card utility, then use Win32 DiskImager to write the image I want to use?
(07-16-2016, 08:08 AM)bigben Wrote: Hi,
If you tried phoenix utility is not success ,
Did you try download DD version Remix os or Android use Win32 Disklmager burn your micro sd card ?
If I am wrong please correct my content , thank !
1. Use Pine64 Running Ubuntu 16.04 Web Server ( LAMP )
2. Use Pine64 Running Official Android 6  for Media player
3. Use Pine64 Running Volumio Digital Audio Player
Burn either a PhoenixCard image with PhoenixCard software, or a DD image with Win32DiskImager. You can't use an image meant for PhoenixCard on Win32DiskImager and vice-versa. Use either PhoenixCard or Win32DiskImager, with an appropriate OS image.
I think you may be trying to burn a DD image using PhoenixCard. Here are links to the latest Android and RemixOS images meant for PhoenixCard:
RemixOS:
http://files.pine64.org/os/remix/remix-v...ixCard.zip
Android:
http://files.pine64.org/os/android/andro...ixCard.zip
RemixOS:
Android:
When trying to burn the disc image (with Phoenixcard) of the android image you linked to above, I format to normal (says successful) and then select Startup, select the image and select burn.
Says formating the card and gives error message in popup "Card Process failed !228"
It does so on two different Sandisk 32 GB Ultra Plus cards ...
Suggestions?
I get the message
RemixOS:
Android:
Suggestions?
I get the message
Hi. If I recall correctly (I may not), some people got around this problem by using an external USB microSD card reader, rather than their computer's in-built reader. This is apparently because many in-built readers are unable to write partition tables.
  Is there another link for Android images? Maalth 3 14,250 10-10-2019, 07:57 AM
  Reducing Android Image download size. KPhillisJr 4 13,217 08-21-2017, 04:48 AM
Last Post: winstongel
  Is there an android tv image out there where I can install netflix? eclay 2 9,553 07-18-2017, 08:49 AM
Last Post: eclay
  No Ethernet on Andriod rvalecruz 5 15,082 05-05-2017, 01:59 AM
Last Post: Quezbeme
  Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1] rookieone 15 36,025 05-05-2017, 01:50 AM
Last Post: Quezbeme
  Where do we leave feedback for curated images? howardsternisbatman 0 3,736 01-26-2017, 03:18 PM
Last Post: howardsternisbatman
  android image & sd card size problems tomarneson 11 27,894 01-24-2017, 05:31 AM
Last Post: ayufan
  Tutorial: How to create DD images with appropriate size tkaiser 5 19,060 12-20-2016, 08:17 AM
Last Post: Bluphire
  Android Images Supporting Hardware speedro86 2 7,239 12-19-2016, 07:25 PM
Last Post: Toriless
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 38,046 10-29-2016, 04:31 AM
Last Post: joe
