(03-09-2017, 07:20 AM)kenneth558 Wrote: Yes, I did but didn't think to include it because the swapon command produced no response. My bad in not posting that info. Thank you kindly for asking. Did you enable swap via fstab instead?
I run 1GB/2GB boards headless, so haven't run into any memory issues as yet, so I haven't needed to enable swap space on the pine64 (yet!)
martinayotte has since posted the way I would normally create and enable swap files. When working with swap partitions, you still use the mkswap command to prepare the swap space and swapon to enable it. And you can add either the file or partition version of swap space to the /etc/fstab line in order to make it persistent across reboots.
You would add (using the correct path instad of /dev/hdb1) the following to /etc/fstab for a swap partition...
/dev/hdb1 none swap sw 0 0
... or the below (again, replacing /swapfile with the path to the swapfile) for a swapfile.
/swapfile none swap sw 0 0
This article may help if anyone wants to
learn more about the reasons for and how to make swap files/partitions.
