How to compile on other systems for Pine
I'm somewhat familiar with the basic cmake/make/make install recipe for compiling code. The issue is that this usually results in code compiled for the architecture of the host machine (which for me is an Intel Core i7 / x86_64). Compiling code on this machine is lightspeed faster than compiling directly on the Pine.
Are there (I'm sure there are) flags/switches/make-file changes I can make/use when compiling on my desktop so that the resulting binaries will work on the Pine?
I tried this just now "cmake . -DCFLAGS='-maarch64' -DCXXFLAGS='maarch64'" but I didn't see any messages about the architecture changing. I'm waiting for the compile to finish.
Thanks!
Usually you set CROSS_COMPILE=/path/to/toolchain/<prefix> make xyz
CROSS_COMPILE=/opt/gcc-linaro-6.3.1-2017.02-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- ARCH=arm64 make -j9 Image
For example to cross compile a kernel... if you use autotools and ./configure script there are also more options you can set like --target= or --toolchain=, but that depends on the source
Running into blocker after installing aarch-* tools onto my Ubuntu desktop:
drmac@drmac-ubuntu:~$ sudo apt-get install gcc-4.8-aarch64-linux-gnu-base
drmac@drmac-ubuntu:~/percona-xtradb-cluster$ cmake . ... \
  -DCMAKE_C_COMPILER=aarch64-linux-gnu-gcc-4.8 -DCMAKE_CXX_COMPILER=aarch64-linux-gnu-cpp-4.8
(cmake fails)
  The C++ compiler "/usr/bin/aarch64-linux-gnu-cpp-4.8" is not able to compile a simple test program
drmac@drmac-ubuntu:~/percona-xtradb-cluster$ aarch64-linux-gnu-cpp-4.8 -c
aarch64-linux-gnu-cpp-4.8: fatal error: ‘-c’ is not a valid option to the preprocessor
compilation terminated.
drmac@drmac-ubuntu:~/percona-xtradb-cluster$ aarch64-linux-gnu-cpp-4.8 -S
aarch64-linux-gnu-cpp-4.8: fatal error: ‘-S’ is not a valid option to the preprocessor
drmac@drmac-ubuntu:~/percona-xtradb-cluster$ aarch64-linux-gnu-cpp-4.8 -E
^C
drmac@drmac-ubuntu:~/percona-xtradb-cluster$ aarch64-linux-gnu-cpp-4.8 --help | grep assemble
 -Wa,<options>            Pass comma-separated <options> on to the assembler
 -Xassembler <arg>        Pass <arg> on to the assembler
 -E                       Preprocess only; do not compile, assemble or link
 -S                       Compile only; do not assemble or link
 -c                       Compile and assemble, but do not link
                          Permissible languages include: c c++ assembler none
Failing tests are a common problem while cross-compiling since the tests usually try to run their output on the host platform which of course fails if they are aarch64 binaries. I spent a lot of time fixing autotools based projects but I can't really help you with cmake... did you have a look at https://cmake.org/Wiki/CMake_Cross_Compiling?
https://cmake.org/Wiki/CMake_Cross_Compi...rospection deals with your problem
Wink Volumio 3 Pine A64+ unofficial shinzuka 6 2,834 05-28-2026, 02:13 PM
  Pine A64+ mainline mipi-dsi Learnincurve 3 11,995 01-12-2021, 07:36 AM
Last Post: Learnincurve
  DietPi OS for PINE A64 MichaIng 0 15,838 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 10,330 10-02-2020, 11:38 AM
Last Post: mathiraj
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 23,920 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 35,717 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 11,596 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 10,812 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 9,985 05-09-2019, 05:42 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,464 03-30-2019, 06:48 AM
Last Post: ktaragorn
