Do apps run in the background at boot up?
Hi I'm using a Pine64 2GB board and Android 6.0 20170112 16GB (rooted).  I'm trying to get a sync app to load on boot and sync with Dropbox.  It doesn't seem to work unless I manually click the app, in this case FolderSync.  I plan on using this with Video Kiosk to play video loops but I will need to remotely change the videos from time to time.  I've tried using Tasker but it didn't launch the app at boot up either.  I'm not sure Tasker started at boot up either.
Is there something I'm doing wrong?
Thanks for your help!
Penfold
Well I have installed Gmail and Facebook on the Pine running Android and they run as expected after turning on the device. They both display notifications without having to press the icon to start it first. I also tried FolderSync on am old Galaxy S4 running 4.4.4 and it will sync after turning the phone on.
Well it works in Android 5 so I guess I'll use that. Smile
(03-03-2017, 02:13 PM)Penfold Wrote: Hi I'm using a Pine64 2GB board and Android 6.0 20170112 16GB (rooted).  I'm trying to get a sync app to load on boot and sync with Dropbox.  It doesn't seem to work unless I manually click the app, in this case FolderSync.  I plan on using this with Video Kiosk to play video loops but I will need to remotely change the videos from time to time.  I've tried using Tasker but it didn't launch the app at boot up either.  I'm not sure Tasker started at boot up either.
Penfold
solved the issue by downgrading back to android 5.1
i guess the android 6.0 hdmi drivers just don't work as good
  [PINE A64 2GB Kickstarter]How to boot android from external SSD v1n1c1uS 1 5,914 01-15-2018, 11:05 PM
  Kickstarter edition wont boot to android bilbo6209 1 5,846 01-09-2018, 08:03 PM
  Boot hangs on pine64, how to debug? olh 1 5,967 08-29-2017, 12:04 AM
  Auto-starting apps? Green Cherry 4 11,413 08-01-2017, 06:34 AM
Last Post: Green Cherry
  Pine64+ 1G: boot loader details required Tanveer 4 11,573 07-29-2017, 09:07 PM
Last Post: Tanveer
  Pine 2GB won't boot Android anymore Bluphire 5 12,623 05-29-2017, 09:34 PM
Last Post: dkryder
  Custom boot animations Bluphire 4 9,791 05-05-2017, 02:00 AM
Last Post: Quezbeme
  Change Android boot logo? ipsw 5 17,891 05-03-2017, 09:39 PM
Last Post: Quezbeme
  Settings and apps not saved sanverm 3 8,947 09-12-2016, 07:43 AM
Last Post: MarkHaysHarris777
  Can't download apps off Google Play! Bacon Strips 6 14,396 08-31-2016, 12:26 PM
Last Post: DonFL
