Orange Screen All versions of Android TV
I just got my Pinea64 2gb a few days ago and have been trying to get android TV to boot on it. I was able to get the official Ubuntu mate image to work so I know the board isn't bad. I have tried android tv 5.1.1, 6.0, and 7.0. All that happens when I plug it in and turn it on is the screen I'm using (both 1080p one is a large TV and one is a computer monitor, both are using straight HDMI) turns orange and after 10-15 seconds goes black and comes back as orange for 3 minutes before restarting again. Any ideas?
I chatted with two folks last night on the  irc  with this symptom.  One was able to correct the problem by using the 2nd hdmi input on the TV rather than the first.  (this also required a firmware upgrade on the TV )
The second one was able to get it running by using  version 6.0 and the 2nd hdmi input.
hope this helps;  but, it looks like an issue needs to be opened so that ayufan can take a look at it.
(02-08-2017, 10:44 AM)MarkHaysHarris777 Wrote: I chatted with two folks last night on the  irc  with this symptom.  One was able to correct the problem by using the 2nd hdmi input on the TV rather than the first.  (this also required a firmware upgrade on the TV )
I'll test it this afternoon when I'm home for lunch. Thank you for the heads up! I'll let you know if this remedies the issue. Where would I open an issue with ayufan? On the github page for the project?
First try to gather more information, opening an issue that is not really reproducible doesn't make much sense... can you get a serial converter (3,3V) and see what output you have on UART0?
(02-08-2017, 10:51 AM)xalius Wrote: First try to gather more information, opening an issue that is not really reproducible doesn't make much sense... can you get a serial converter (3,3V) and see what output you have on UART0?
I'm going to Fry's this afternoon and can probably pick one up from there. It's reproducible for me.  Wink Do you have any recommendations for which one I should get or which ones are compatible?
Any USB-serial converter with 3,3V levels should do, I prefer the ones that have FTDI or PLxx chipsets since those usually work across all platforms without issues... something like https://www.adafruit.com/product/954 those single connectors at the end of the cable are really handy since you can connect them to any header regardless of the pinout
I can confirm this problem too. It must have recently started (I'm using android 6.0). The previous version I was using worked great with no video problems. Something seems to have changed in the recent ones. Neither HDMI input works (both orange screen), edited the boot file to set resolution and tried tinkering with the "hdmi0 hdmi1" options. Still the same problem.
Tried burning the image with DD and Etcher - both same result.
Previous versions worked fine however.
Cheers
(02-08-2017, 11:02 AM)xalius Wrote: Any USB-serial converter with 3,3V levels should do, I prefer the ones that have FTDI or PLxx chipsets since those usually work across all platforms without issues... something like https://www.adafruit.com/product/954 those single connectors at the end of the cable are really handy since you can connect them to any header regardless of the pinout
Just ordered that one off of amazon with same day delivery. I'll let you know my results once I get it.
(02-08-2017, 12:28 PM)veronicasmithen03 Wrote: I can confirm this problem too. It must have recently started (I'm using android 6.0). The previous version I was using worked great with no video problems. Something seems to have changed in the recent ones. Neither HDMI input works (both orange screen), edited the boot file to set resolution and tried tinkering with the "hdmi0 hdmi1" options. Still the same problem.
Cheers
Thank you for the input! If you find any solution please let me know. I have tried both Etcher and win32 disk imager. I messed with the resolution, hdmi0/1, and hdmi cec settings with no improvement. I'll let you know if I figure anything out.
Pre-release are broken. Ayufan removed them
17:55:29 <ayufan> Pre-release is broken Confusedlightly_smiling_face:
17:55:30 <ayufan> Simply
(02-08-2017, 01:38 PM)Luke Wrote: Pre-release are broken. Ayufan removed them
I am pretty sure I have tried the ones marked as stable as well. I'll download one now. Which version should I get? 6,7,or 5?
  Need help compiling android for pine a64 + YeeticusMaximus22 1 1,534 12-13-2025, 09:23 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 575,489 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 46,910 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 29,955 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 11,790 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 13,144 10-10-2019, 07:57 AM
  screen rotating Miguelito71 0 4,889 07-29-2019, 12:48 AM
Last Post: Miguelito71
Question Android SDK Oreo NGC6691 2 9,771 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,203 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 388,994 03-12-2019, 04:53 PM
Last Post: neosapien
