Windows 10 IoT finally released on Pine A64 platform
#21
(08-04-2016, 07:27 PM)tllim Wrote: The Pine A64 already passed the Windows 10 Azure IoT certification: https://azure.microsoft.com/en-us/docume...gurations/
For the Pine A64 Windoiws IoT installation process, please refer to https://github.com/Azure/azure-iot-sdks/...-csharp.md
For the Pine A64 Window IoT code, please download from Pine64 file server: http://files.pine64.org/os/win10-iot/Win...Pine64.ffu
For developer that interest on the Pine A64 Windows IoT SDK, please stays tune. We will release the UEFI source code and Win10 BSP SDK package in few weeks time Smile
Links for azure  and  github not working. Code link downloads.
Save
#22
Hi all,
Using windows10IoT_pine64_RS1_20161121.ffu (OS Version: 10.0.14393.0), cant seem to get it to boot with WiFi/Bt module, BSOD every time.
Remove the module and it starts up fine.
Windows Update installs: 10.0.10595 and then when rebooting, it just hangs. This is what I get on the console. ------------------------ ��%���5jR�AXP NumberOfHandles = 1                 �U͉ɂJ�с�QIQ�"""jԤ�5�!�����        open hci clock usbc_no:1, is_ohci:1        parser fetch usbc1 usb_drv_vbus_gpio failed        Loading driver�SunxiEthDxeEntryPoint: phy mode = rgmii        gmac_rgmii_select        Loading drive�no key pressed        Sunxi BootCmd = boot-normal        Loading drive�Loading�Loading dr�Loading d�Loading driver at �Loading driv�Loading drive�[PWM Msg]:request pwm success,pwm-base=0x0, pwm_number=1,pwm = 16.        enable power vcc-hdmi-33, ret=0        drv_disp_init finish        [Disp Msg]:board_display_device_open_lcd        [Disp Msg]:boot_disp.output_mode=4        [Disp Msg]:disp0 device type(0) enable        lcd_panel_fun[0].cfg_open_flow is NULL        enable power vcc-dsi-33, ret=0        disp_sys_register_irq, irqNo=121, Handler=0xBE592F09, pArg=0xBE316810        lcd_panel_fun[0].cfg_panel_info is NULL        disp 0, clk: pll(330000000),clk(330000000),dclk(55000000) dsi_rate(55000000)        clk real:pll(330000000),clk(330000000),dclk(82500000) dsi_rate(148500000)        lcd_panel_fun[0].cfg_open_flow is NULL        lcd_panel_fun[0].cfg_open_flow is NULL        [Disp Msg]:board_display_device_open_hdmi        [Disp Msg]:boot_disp.output_mode=4        [Disp Msg]:disp1 device type(0) enable        attched ok, mgr1<-->device0, type=4, mode=4        disp_sys_register_irq, irqNo=119, Handler=0xBE5989E5, pArg=0xBE316610        plugin        [Disp Error]:fetch script data boot_disp.output_full fail        [Disp Msg]:screen_id =1, screen_width =1280, screen_height =720        [Disp Msg]:frame buffer address BF000000        [Disp Msg]:bitcount = 32        [Disp Error]:fetch script data boot_disp.output_full fail        [Disp Msg]:screen_id =0, screen_width =1024, screen_height =600        [Disp Msg]:frame buffer address BF000000        [Disp Msg]:bitcount = 32        Loading driver a�Loading driver �Loading driver at 0x�Loading drive�Loading dri�Loading driver�Loading driver at 0x000BE1AF000 EntryPoint=0x000BE1B26A1 Fat.efi        Loading driv�Driver CB933912-DF8F-4305-B1F9-7B44FA11395C was discovered but not load�+&��+LL'LL���O&Z�+&��+LL'LL��+&��+LL'LL���O&Z�+&��+LL'LL��+&��+LL'LL���O&Z�+&��+LL'LL��+&��+LL'LL���O&Z�+&��+LL'LL��+L[���M[�+ML[�+L[���Sk�E�jمɥ ������꽽ѵr�ɵ��5jRT����݁��с������5jR�Loading driver�ACPI: LoadAcpiFromVolume() failed to open directory        ACPI: Loading ArmBgrt.acpi        read file is NULL        read file is NULL        ACPI: Loading ArmCsrt.acpi        ACPI: Loading ArmDbg2.acpi        ACPI: Loading ArmDsdt.aml        ACPI: Loading ArmFacp.acpi        ACPI: Loading ArmGtdt.acpi        ACPI: Loading ArmMadt.acpi        ACPI: Loaded 7 tables        Install ACPI table by partition file success        no battery exist        read file is NULL        read file is NULL        read file is NULL        Read Logo file Fail, Please Check file exist        show Bootlogo error: Unsupported        PEI    644 ms        DXE   1577 ms        BDS    333 ms        Total Time = 2554 ms
try removeable media boot
Any ideas what is wrong?
Cheers
-Anders
#23
(02-06-2017, 08:35 AM)carlberg Wrote: Hi all,
I have reported the exact same problem. Unfortunately sofar
no one has reported or followed up since.
if anyone with the right sources could help out is very much appreciated.
Mod Edit: Post restored - was not a duplicate
#24
hi , I removed the duplicate (very lengthy post) and edited the last post with a code block.
Please keep lengthy log posts or code within a code block for other user's readability.
Thanks.
Wink
#25
That was my post which you removed...
In short, I already reported earlier the same as carlberg's findings: WiFi + BT add-on causes crash of PINE64 on boot. Just bumping this thread up to confirm his finding.
Only, seems to me we're shouting into a void here... or is there progress of any kind on Windows IoT for PINE64?
#26
quisiera saber si a alguien le funciona el sistema operativo de w10 iot en la pine64+ 2gb..
No me arranca a mi , el archivo .ffu no me sirve...no es autoarrancable..
gracias espero sus respuesta ...saludos desde latinoamerica..
I would like to know if someone works on the w10 IoT operating system on the pine64 + 2gb ..
It does not boot me, the .ffu file is not useful ... it is not self-extracting ..
Thank you, I hope your answers ... Greetings from Latin America ...
  Windows 10 IoT Enterprise? roybridge 1 21,145 03-06-2019, 02:42 PM
  Windows IoT BSP dvescovi 16 44,411 09-02-2018, 06:35 PM
Sad Windows 10 iot ffu lawrencejd 1 8,559 07-19-2018, 10:40 PM
Last Post: KNERD
  Win10 IoT (PINE A64(+)) 10.0.15063.0_20170602 pineadmin 30 78,490 05-18-2018, 07:05 AM
Last Post: dkryder
  +LTS/SOPINE Can Win10 IOT be used on PINE A64-LTS? uart 1 7,846 03-09-2018, 11:25 PM
  unable to deploy my application to the Pine using Visual Studio 2017 Matthew 9 23,028 03-08-2018, 04:20 AM
Last Post: zio69
  Will Windows 10 work with the new Rock board? WhiskerBiscuit 2 10,261 09-03-2017, 07:22 PM
  Windows 10 and .Net Core running for a day hugob 2 10,948 08-23-2017, 11:17 AM
Last Post: hugob
Star Windows IoT BSP on Github!!!! Add UEFI src code! Leeway213 5 18,474 06-25-2017, 07:42 PM
Last Post: Leeway213
  Pine 64 on 512MB embedder 3 12,784 12-19-2016, 07:56 PM
Last Post: Toriless
