Cable for LCD
I have ordered the 7" LCD with my board which lists a 4 Lane MIPI DSI Ribbon Port. What cable do I need to connect it to my board?
Thanks,
(02-17-2016, 01:20 PM)sbentjies Wrote: I have ordered the 7" LCD with my board which lists a 4 Lane MIPI DSI Ribbon Port. What cable do I need to connect it to my board?
Thanks,
It should come complete with the relevant cable Smile
Thanks,
Yeah that would be shitty for it not to...
Thanks,
The LCD panel comes with its own flat flex type cable.
Thanks,
Which attaches to a port on the board I assume
Thanks,
Yes. attached to both LCD and TP ports.
Thanks,
TP?
Thanks,
TP?
Touch panel.
Hello, I noticed that Pine A64 uses MIPI DSI and touch port.  I know the MIPI DSI is 4 pin but what kind is the touch controller port?  Will this work?  It says it has S3402 touch ic controller.  I have also seen some with S3508 touch ic.
(02-28-2016, 12:59 PM)matthewclso Wrote: Hello, I noticed that Pine A64 uses MIPI DSI and touch port.  I know the MIPI DSI is 4 pin but what kind is the touch controller port?  Will this work?  It says it has S3402 touch ic controller.  I have also seen some with S3508 touch ic.
You can't assume that touch panel controllers are interchangeable.  If you can't find out more about that touch IC and find an existing linux driver for it, you won't get it to work out of the box without writing or adapting a different driver to it.
  Ribbon Cable Extenders ? Severian 14 30,879 08-04-2016, 02:11 PM
Last Post: jodybrown99
