Z Wave Module and still using GPIO
Hi.
Just realized that the Z wave module is connected to the full GPIO Sad
Is there anyway you still could use any GPIO pins (for input / output) when the Z wave module is connected?
Is it using all of the pins ?
Also very disappointed that the Z wave module makes it impossible to use the Pine64 case (lid wont fit)...
regards,
bang
(01-14-2017, 06:25 PM)bang Wrote: Just realized that the Z wave module is connected to the full GPIO Sad
hi bang, the Z-wave module is a uart(x) device; that is, it is controlled ( in the case of the module that plugs into the PI bus ) by uart(2) on device /dev/ttyS2.
The module does not have to be plugged into the bus pins with the adapter;  it may be connected ( with proper knowledge ) to the uart of choice ( uart(2) pi bus, uart(3) euler bus, uart(4) euler bus ).
The only pins that are required is the Vcc, ground, Tx, and Rx pins.
The Z-wave modules are serial devices.
Thanks!
If I just had taken the time to have a closer look at the Z Wave modul and the adapter I should have realized that my self Smile
So if the adapter was better I would have been able to use the GPIO AND fit the lid....
There isn't by any chance an adapter that's already doing this Smile ?
The other connector (EULA ?), is it possible to use this as an input (detecting hi/low) just as easy as the GPIO? If so, what pins should I use and how is the reading?
Question Z-Wave module pinout to make it compatible with Pi b+ ebretteville 59 137,538 07-12-2019, 08:55 AM
Last Post: kris240376
Sad Z-Wave and openzwave+node-openzwave-shared saro 2 10,219 09-01-2017, 05:22 AM
Last Post: saro
  Z-Wave - Full and Low Power Inclusion mode B34N 1 7,369 03-26-2017, 06:03 PM
Last Post: B34N
  KICAD Quick Lib and Module Generator mbt28 1 7,880 02-12-2017, 10:45 PM
  Z-Wave US module with adapter aegrotatio 4 12,445 01-08-2017, 12:03 AM
Last Post: aegrotatio
  RaZberry Module (z-wave) need support to get it working! Luxus 13 30,906 11-03-2016, 02:04 AM
Last Post: Luxus
  Z-Wave module problem vintagewaffle 0 3,859 10-26-2016, 10:50 AM
Last Post: vintagewaffle
Video Australia/New Zealand Z-Wave module Jnimmo 46 98,519 10-02-2016, 02:25 PM
  [EU] Z-Wave module tutorials? meowbot 2 8,296 09-13-2016, 07:54 PM
Last Post: Ghost
  New module: POT board Crispin 25 63,875 07-12-2016, 08:47 PM
Last Post: khgoh
