Power Cord & SD Card
I recently got a Pine 64 board along with a Power Cord, SD Card, Camera, Humidity Sensor. I have *somehow* misplaced the Power Cord & SD Card. I am oblivious as to how I done so but I did, sadly.
Is it possible any of you could send me one via the mail? I live in the United States.
Not sure Pine Inc will cover you on that, since by your own admission you misplaced them. Anyway, you could try contacting support:
https://support.pine64.org/portal/home
Or you could try and source your own replacement power supply and microSD card. Power supply needs to be 5V 2A minimum. Amperage (A) can be higher, but should not really be lower than that. Voltage should be 5V or thereabouts - some might be 5.1V, or 5.2V, possibly even 5.3V - this helps to mitigate some of the voltage drops caused by the inefficiency of the micro USB connection as a stable conduit of power. Providing power to the board via the Euler bus is recommended, but that is something for another discussion, perhaps.
Most microSD cards will work. Samsung Evo (Plus) cards have become recommended, due to their solid performance in terms of random read/write speeds. Many microSD cards prioritise linear read and write speeds over random r/w - traditionally, the class of card is not much of an indicator of random r/w performance.
Question +LTS/SOPINE USB voltage on power off using LiPo battery GregH 0 5,423 05-06-2020, 11:23 PM
Last Post: GregH
  Battery case and power question Twistedx 2 10,025 12-24-2018, 08:04 PM
Last Post: Twistedx
Photo Smart Card Reader Support bymrz 2 8,402 02-18-2017, 04:05 AM
Last Post: bymrz
  Can't get power button to work AidenH 17 36,809 08-28-2016, 07:19 AM
Last Post: DonFL
  Wires as power button Nittola 5 12,190 08-19-2016, 03:35 PM
Last Post: MarkHaysHarris777
  Trouble getting ISO on to MicroSD card Fawks 3 9,676 06-08-2016, 06:17 PM
Last Post: Luke
  Power Jumper rahlquist 12 27,098 04-03-2016, 09:29 AM
Last Post: SkimMilk
