QT5 on Pine64
I have an xprotolab plain o-scope.  The software for it is written in QT, which means that, in theory, I should be able to get it running on the Pine64.
My only problem is that I have QT4 by default, and need QT5.
How do I go about installing QT5 and telling the system to use QT5 instead of QT4?  I've searched online, and all it's done is confuse me.
Once QT5 is installed, I think it's just a matter of running cmake to make the software.
Thanks in advance!
RIck
(01-01-2017, 01:11 PM)rickseiden Wrote: I have an xprotolab plain o-scope.  The software for it is written in QT, which means that, in theory, I should be able to get it running on the Pine64.
Thanks in advance!
RIck
We are currently work on Ubuntu Core with QT Embedded. However, I don't knwos the QTe version number and will check with involved engineers. This build plans to release in two weeks time.
The xprotolad is an interest project and please share your progress.
Which image are you running? Depending on what the exact requirements for the scope software are, you might have to build Qt and friends together with the source on the Pine...
(01-02-2017, 06:47 AM)xalius Wrote: Which image are you running? Depending on what the exact requirements for the scope software are, you might have to build Qt and friends together with the source on the Pine...
I'm sorry.  Such an obvious thing that should have been included.  I'm running the Debian image.
Thank you
Rick
แทงคาสิโนออนไลน์
  Programming languages support under PINE64 baryluk 6 20,776 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 10,715 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 39,389 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,697 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,164 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 57,568 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,993 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,662 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,702 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 60,310 10-26-2017, 05:51 PM
Last Post: gregjo
