Ultrawide Display for Ubuntu Mate DE
Question
Is this possible? Trying to use a 21:9 monitor (2560x1080p60). The only resolution open is standard 1080p resolution.
(12-31-2016, 03:09 PM)dudeytsang Wrote: Is this possible? Trying to use a 21:9 monitor (2560x1080p60). The only resolution open is standard 1080p resolution.
You can try to define the resolution and timings in X using CVT and xrandr. It's been a long time since I did this, but you can try what's mentioned in this post:
http://askubuntu.com/questions/377937/ho...resolution
Put in whichever width, height and refreshrate you want in CVT and use the commands that follow on xrandr. I have no guarantee this will work on the A64 SoC, so good luck.
Should it work, post your results in the thread as it will be great for other users.
First generate a "modeline" by using cvt
Syntax is: cvt width height refreshrate
cvt 1680 1050 60
this gives you:
# 1680x1050 59.95 Hz (CVT 1.76MA) hsync: 65.29 kHz; pclk: 146.25 MHz Modeline "1680x1050_60.00"  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync
Now tell this to xrandr:
sudo xrandr --newmode "1680x1050_60.00"  146.25  1680 1784 1960 2240  1050 1053 1059 1089 -hsync +vsync
Then you can now add it to the table of possible resolutions of an output of your choice:
sudo xrandr --addmode VGA-0 1680x1050_60.00
  Issues with both Deb and Ubuntu germanshep 0 4,431 08-28-2018, 05:47 PM
Last Post: germanshep
  Help debug my pine64A+ ubuntu/plex hangs XaRz 8 17,045 11-02-2017, 06:34 AM
Last Post: XaRz
  Rotate Display boyatomic 2 8,051 03-07-2017, 06:47 PM
Last Post: Kiwiboyus
  Ubuntu 16.04 cannot resolve dns - connection timed out; no servers could be reached marcosti 2 13,123 03-01-2017, 02:46 PM
Last Post: dkryder
  Pine64+Ubuntu+Tvheadend+DVBT Dongle Shai 3 10,685 10-03-2016, 04:23 AM
Last Post: Shai
  Dmesg output Ubuntu Mate S265 1 5,901 10-02-2016, 07:28 AM
Last Post: MarkHaysHarris777
  Overclocking ubuntu mate Mixermic 2 8,028 10-01-2016, 04:36 AM
Last Post: pfeerick
  How to make multicast working on ubuntu and debian brengthdom 3 10,648 09-18-2016, 02:05 PM
Last Post: brengthdom
  Camera support - Ubuntu Xenial 16.04 LTS @lex 3 8,950 08-07-2016, 03:47 AM
Last Post: romansavrulin
  [How-To] Make PINE 64 with Ubuntu Xenial Longsleep build crunch BOINC Tasks moisesmcardona 3 12,287 07-27-2016, 01:16 PM
Last Post: NexusDude
