Facing difficulty in getting started with Ubuntu image
1. I downloaded longsleep image (xenial-pine64-bspkernel-20161218-1.img.xz) !
I burned image and booted too.
I do not have any monitor with me. I do not have any keyboard with me. (actually i do not want to use it.)
How, can i do it. I used different hardware, where device was connected to Laptop. When C.H.I.P. was connected to laptop, using usb cable, I do not need cable. I just need to use screen utility to login on any tty
I connected a monitor and keyboard to what is available.. after login, I tried, ifconfig. ifconfig do not show any wlan0. I have connected my wifi module to Pine64. so, ideally it should show wlan0 too. unable to find instruction on how to connect wifi.
the worst thing, I tried to connect with LAN cable.  router is very far from Work table. If I connect LAN cable, I cannot connect keyboard. So I thought , I can do ssh and let Pine64 to be connected on LAN cable without any keyboard.
When I connected with a LAN cable, It do not get any ip address. It should get ip address automatically, so that I can do a ssh.
I am highly frustrated, I cannot get stated on this board.
Somehow, It is getting ip address. I can do a remote ssh and login too.
But problem is still same..
trying to get connected with Wifi !!
My Wifi is not working, I am using original Wifi module from Pine. I am also using original charge from Pine.
Here are my logs
ubuntu@pine64:~$ dmesg | grep wlan
[ 8.933130] sunxi-wlan wlan.27: wlan_busnum (1)
[ 8.938176] sunxi-wlan wlan.27: Missing wlan_power.
[ 8.943618] sunxi-wlan wlan.27: wlan_power_name ((null))
[ 8.949535] sunxi-wlan wlan.27: io_regulator_name (vcc-wifi-io)
[ 8.956150] sunxi-wlan wlan.27: wlan_regon gpio=354 mul-sel=1 pull=-1 drv_level=-1 data=0
[ 8.965684] sunxi-wlan wlan.27: wlan_hostwake gpio=355 mul-sel=6 pull=-1 drv_level=-1 data=0
[ 8.975497] sunxi-wlan wlan.27: clk not config
[ 13.730099] sunxi-wlan wlan.27: bus_index: 1
[ 13.745621] sunxi-wlan wlan.27: check wlan io_regulator voltage: 1800000
[ 14.193745] RTL871X: rtw_ndev_init(wlan0)
[ 14.207622] RTL871X: rtw_ndev_init(wlan1)
ubuntu@pine64:~$ ifconfig
eth0 Link encap:Ethernet HWaddr 36:d5:2b:db:21:7b
inet addr:192.168.1.203 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::34d5:2bff:fedb:217b/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:512 errors:0 dropped:0 overruns:0 frame:0
TX packets:332 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:44625 (44.6 KB) TX bytes:43405 (43.4 KB)
Interrupt:114
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:80 errors:0 dropped:0 overruns:0 frame:0
TX packets:80 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:5920 (5.9 KB) TX bytes:5920 (5.9 KB)
Detailed logs available at - https://gist.github.com/nsisodiya/925b80...9ae26b9ee4
Wifi working... - followed instructions on - http://forum.pine64.org/showthread.php?t...&pid=18823
Glad you got it working. For these sort of questions, if you can't find the answer in the forum, it may be a good idea to ask in the chat first --- there is a chance that someone will know the answer or will be able to point you to the right forum thread.
  Ubuntu server 20.04 request phi0x 2 10,998 12-30-2020, 08:02 PM
Last Post: phi0x
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,431 08-30-2020, 10:35 AM
Last Post: jrronimo
  Kickstarter P64 with LCD, working image? MostHated 1 7,907 01-04-2020, 10:32 AM
Last Post: igorp
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 8,436 02-01-2019, 05:09 AM
  SPI on ubuntu IlyaM 4 14,601 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,217 05-18-2018, 03:33 PM
Last Post: Luke
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,515 02-01-2018, 09:45 AM
Last Post: Partymack711
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 930,061 01-31-2018, 11:58 AM
Last Post: Luke
  PPTP doesnt work with ubuntu escovedo 2 13,480 08-23-2017, 09:28 AM
Last Post: gilbertotcc
Question HELP Ubuntu Mate password recovery procedure Captain Anni Hilator 5 15,366 08-03-2017, 03:52 PM
Last Post: Luke
