Dallas 1-Wire Support
#31
(11-30-2016, 02:23 PM)martinayotte Wrote: You don't need to do modprobe, it should comes automatically.
Check you DTS again, use "gpios = <0x30 0x2 0x8 0x0 0x0 0x0 0x0>;", recompile the DTB, reboot, and recheck.
Otherwise, it must be a wiring problem.
I believe that gpio PC8 as in the DTS is pin 12 on the PI bus.  Try connecting the data line there instead of to pin 7.
Thanks Wom the Bat, that was it. It's working now.
Question RGB LED Matrix support? foxnox 1 6,928 12-29-2017, 06:52 PM
Last Post: psychedup
  RaZberry Module (z-wave) need support to get it working! Luxus 13 30,306 11-03-2016, 02:04 AM
Last Post: Luxus
  USB WIFI Dongle Support InCognito 3 10,509 01-20-2016, 11:27 AM
