How to open Playbox with screen installed?
Finally got around to trying to put together the parts I bought through the Kickstarter campaign. I'm missing the long touch screen ribbon cable that's supposed to come with the Playbox, so I decided to call it a night and closed up the box... with the screen installed. It didn't occur to me until that instant that there are no slots in the Playbox to push a tool to disengage the tabs that hold the it together. Does anyone know an easy trick to re-open the Playbox without just prying it apart?
(12-02-2016, 09:52 PM)LAPine Wrote: Finally got around to trying to put together the parts I bought through the Kickstarter campaign. I'm missing the long touch screen ribbon cable that's supposed to come with the Playbox, so I decided to call it a night and closed up the box... with the screen installed. It didn't occur to me until that instant that there are no slots in the Playbox to push a tool to disengage the tabs that hold the it together. Does anyone know an easy trick to re-open the Playbox without just prying it apart?
Carefully use a dremel tool and place a very small hole at each tab point;  be careful to not drill through the tab !!
Then, use a paper clip to push the tab via the hole just drilled !
I used a credit card.
Verstuurd vanaf mijn Nexus 6P met Tapatalk
I ended up using a small cutting bit to plunge cut some holes in the case. Thanks!
Sent from my iPhone using Tapatalk
  7" LCD Touch Screen Panel IanJames 0 3,539 04-01-2020, 04:40 PM
Last Post: IanJames
  User Screen Black After Changing Power Settings 0b51Gekko 2 8,110 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
Question Playbox enclosure help odatkid 3 9,909 10-23-2017, 03:24 PM
Last Post: Luke
  Rock64 + 7" touch screen naviathan 2 7,592 09-28-2017, 09:01 AM
Last Post: naviathan
  7" Screen - Does it work with Debian abasel 1 6,270 07-26-2017, 05:44 AM
Last Post: pfeerick
  RESOLVED - LCD screen not working, HDMI does asuras 10 24,634 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI-VGA adapter. Blank screen. trumad 10 27,875 03-05-2017, 03:17 AM
Last Post: pfeerick
  Does ubuntu img support the touch screen kingsing2 4 11,945 01-29-2017, 02:41 PM
Last Post: greglarious
  Can't get past boot screen... (RESOLVED) codetheweb 13 36,062 01-19-2017, 08:43 AM
Last Post: Michaelrowe01
  LCD touch pad blank screen tanarri 20 47,867 09-22-2016, 01:20 PM
Last Post: Ghost
