What Ubuntu image for GUI?
Hi
I've spent a considerable amount of (wasted) time already trying to get a gui up and running on my 2GB Pine.
This thread seems to just deteriorate from it working to 'well I guess it doesn't work anymore'.  Isn't there a working Ubuntu GUI image available for download?
thanks,
Hi
There is. Look in the wiki downloads section - Ubuntu Desktop image. I do strongly recommend you use the base image and install a DE yourself instead ...
But yea, its there.
(11-30-2016, 11:54 AM)howardsternisbatman Wrote: Hi
thanks,
As Luke pointed out, there is a image with a desktop environment available. However, I experienced the same issue as you did, and resolved it by installing aptitude and telling it to work around the underlying dependency issues.
I basically installed the same packages that the included "install_mate_desktop.sh" script does, but used aptitude so I could use it's more advanced dependency workaround logic.
aptitude install xserver-xorg-video-fbturbo ubuntu-mate-core ubuntu-mate-desktop ubuntu-mate-lightdm-theme ubuntu-mate-wallpapers-xenial lightdm
It told me in first instance that it could leave things as they were - i.e. not install the packages that had dependency issues, and I told it that wasn't good enough (n). The second option it gave me was to then install the required versions packages that were causing problems, and then install everything, and I accepted that. After it had installed everything, I then ran the "install_mate_desktop.sh" script and let it put in the final tweaks and patches needed, and I was able to run Ubuntu Mate without any issue. This was when starting from the 20160716 Ubuntu Xenial minimal image.
So it is possible, but not for the faint hearted... as misuse of aptitude can break your system! :-O
  Ubuntu server 20.04 request phi0x 2 11,301 12-30-2020, 08:02 PM
Last Post: phi0x
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,804 08-30-2020, 10:35 AM
Last Post: jrronimo
  Kickstarter P64 with LCD, working image? MostHated 1 8,134 01-04-2020, 10:32 AM
Last Post: igorp
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 8,691 02-01-2019, 05:09 AM
  SPI on ubuntu IlyaM 4 14,911 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,492 05-18-2018, 03:33 PM
Last Post: Luke
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,913 02-01-2018, 09:45 AM
Last Post: Partymack711
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 950,500 01-31-2018, 11:58 AM
Last Post: Luke
  PPTP doesnt work with ubuntu escovedo 2 13,753 08-23-2017, 09:28 AM
Last Post: gilbertotcc
Question HELP Ubuntu Mate password recovery procedure Captain Anni Hilator 5 15,651 08-03-2017, 03:52 PM
Last Post: Luke
