clone copy of sd card by using partclone
Wink
Hi all
sd card is /dev/sdc Exclamation .
1) backup
dd if=/dev/sdc of=~/Pine-mate-MBR.img bs=512 count=10000
partclone.vfat -c -s     /dev/sdc1          -o    ~/Pine-mate-sdx1of3.pcl
fsck /dev/sdc2
partclone.ext4 -c -s     /dev/sdc2          -o    ~/Pine-mate-sdx2of3.pcl
and then i put anothe sd card  into USB . Exclamation
2)restore
dd if=/root/Pine-mate-MBR.img of=/dev/sdc bs=512
partclone.vfat -r -s /root/Pine-mate-sdx1of3.pcl -o /dev/sdc1
partclone.ext4 -r -s /root/Pine-mate-sdx2of3.pcl -o /dev/sdc2
mkswap /dev/sdc3
all is done . Big Grin
this is much faster by using dd . Heart
regards
Interesting...
(11-03-2016, 09:09 PM)MarkHaysHarris777 Wrote: Interesting...
thanks for reply .
about
10000 is too big .
i don not know best value  .
and
this line hard copy of MBR(?) and partition structure . Idea
if you want full size of partition 1  , you should use gparted Tongue .
and this method is applicable for btrfs arch linux Heart  (partclone.btrfs)
regards
what do you mean by USB?
what about the FIRST SD card, are there still open files when you remove it?
why do you never use command sync?
(11-03-2016, 10:02 PM)dkryder Wrote: what do you mean by USB?
arch linux PC:USB port------ Exclamation sd card reader Exclamation ------sd card in which pine64 lives .
no,
cloning to img , and then clone to another sd card .
so mass productin is easy Angel .
in btrfs , rsync is impossible
1)btrfs cloning itself
https://youtu.be/eFfKmEh6KO8
2)and then gparted
https://youtu.be/wRpEqggWS8w
regards
This actually has some cool application:  if we start providing a service ( like noobs on Raspberry PI ) to mail out SD cards for folks that don't want to go to the trouble of making their own.
difinitely worth looking into.
(11-03-2016, 10:17 PM)hatahata Wrote: in btrfs , rsync is impossible
sync, not rsync. And it is probably a good idea to do it before removing the target microSD, just in case you yank it out as it's finishing flushing the buffers to disk... although the flashing light (if there is one) on the microSD card reader is usually a giveaway that it hasn't really finished yet. Wink
  resize root partition to max available space SD card can provide bilylilyli 16 35,954 11-18-2016, 07:10 PM
Last Post: pfeerick
Sad How to resize the root partition in order to fully utilize the SD Card MicroDiery 5 12,954 05-24-2016, 05:48 AM
Last Post: Luke
