GStreamer: XIO: fatal IO error 11 (Resource temporarily unavailable) on X server
I have developed a simple GStreamer application. Works on laptops, desktops and Raspberry Pis. On PINE64 it works too, but only with autovideosink under X, not glimagesink under X. The error is
XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0.0"
      after 23 requests (22 known processed) with 0 events remaining.
This application is fairly simple, hence that it is a good way to test support for GStreamer by a certain distribution. Source code can be found at https://github.com/z25/gstcam
Note that I have configured my system according to https://github.com/avafinger/guvcview_2.0.4/issues/1 and use that particular USB camera. The application works (only from terminal in X) with the -a option. :-) It does not work from a normal terminal (Error: Failed to conenect to X display server)
The error above occurs when (from X) this application tries to use glimagesink. What is the reason that this occurs? The application should switch automatically to autovideosink when there is no glimagesink. So there is support for GL but somehow barks runtime. Any thoughts?
Solving this will increase support for GL on PINE64.
  Ubuntu server 20.04 request phi0x 2 11,309 12-30-2020, 08:02 PM
Last Post: phi0x
  systemd-gpt-auto-generator: failed to dissect: input/output error jeanclaude.magras@gmail.com 0 4,871 12-11-2019, 04:10 PM
Last Post: jeanclaude.magras@gmail.com
  config error installing XML-RPC on longsleep Ubuntu tinkertom 2 7,707 02-22-2017, 06:50 AM
Last Post: MarkHaysHarris777
  Error load mate desktop environment b.simp404 2 6,782 01-21-2017, 02:24 PM
Last Post: wizkidcom
  Finally got Emby server running on Pine64 clarkss12 3 9,992 11-08-2016, 06:04 PM
Last Post: clarkss12
  Error When Resizing SD Card Bob123456789 4 9,139 07-07-2016, 11:06 AM
Last Post: Bob123456789
  Network Access Error coolnine98 5 12,502 06-29-2016, 06:15 PM
Last Post: coolnine98
  Low Transfer Speeds from Pine Samba Server preimmortal 3 8,697 05-16-2016, 12:12 AM
Last Post: ebclr
  System program problem detected error ebclr 0 3,708 05-15-2016, 09:18 PM
Last Post: ebclr
  Mounting USB hard drive - error registering v4l2 subdevice Ruckus 4 9,685 05-13-2016, 06:48 AM
Last Post: Ruckus
