3.5mm Headphone w/ Mic Jack: No Sound
Pine64 (2GB board) setup and mostly running. Have Ubuntu installed w/ Mate desktop started. When I have either 3.5mm headphones or speakers plugged into the Jack there is no sound coming from it. I checked sound preferences Hardware tab and nothing was listed. When I tabbed over to the input and output tabs the input lists the following device "Monitor of Dummy Output" and the output tab lists "Dummy Output - Stereo"
After a couple of restarts it now says I have sound through sndhmi. Hooked it up to TV instead of monitor and sound works. No audio through 3.5mm jack though yet.
Big Grin
(10-08-2016, 10:43 PM)dicenicheserr Wrote: Pine64 (2GB board) setup and mostly running. Have Ubuntu installed w/ Mate desktop started. When I have either 3.5mm headphones or speakers plugged into the Jack there is no sound coming from it. I checked sound preferences Hardware tab and nothing was listed. When I tabbed over to the input and output tabs the input lists the following device "Monitor of Dummy Output" and the output tab lists "Dummy Output - Stereo"
Woot! Got the 3.5mm jack working using the below steps found on a different post.
sudo su
cat <<EOF >/etc/modules-load.d/pine64-audiojack.conf
sunxi_codec
sunxi_i2s
sunxi_sndcodec
EOF
exit
wget https://raw.githubusercontent.com/longsl...ound.state
sudo mv asound.state /var/lib/alsa/asound.state
sudo usermod -a -G audio username
sudo reboot now
The instruciton above did not work for me on latest stable longsleep Ubuntu. Any pointers on how to get this debugged and working?
  Sound teddyj 4 10,622 11-02-2018, 02:28 PM
Last Post: crw
  Pine64 Ubuntu Mate No Sound adamjedgar 3 11,155 11-06-2017, 02:53 AM
Last Post: Luke
  No sound on Android 6 or 7.1 reeno 0 4,347 07-29-2017, 06:31 PM
Last Post: reeno
  NO Sound / nagyatius 1 6,273 02-01-2017, 09:58 PM
  no sound over HDMI mbjpine64 2 7,113 10-09-2016, 01:45 PM
Last Post: dicenicheserr
  Any luck getting JACK working on the pine64? tampadave 1 5,378 09-23-2016, 06:54 PM
Last Post: pfeerick
  Pine Arrived; No Sound in Remix Using HDMI Bob123456789 2 7,299 07-06-2016, 02:02 PM
Last Post: Bob123456789
