cannot play any video
still no gpu driver yet?
im tried to play video with debian and i have try ubuntu too... the audio is good... but the video is really really bad Big Grin
#sorry for my bad english
(10-03-2016, 01:40 AM)aneryan Wrote: still no gpu driver yet?
If you want video please use Android. Video for gnu+linux is going to be a while, if at all ever.
Bad in what way? (the video, not your English Big Grin) I was able to play video with no problems, but it would not go full-screen - even when you maximised the player or tried to go full screen, the video stayed it's original size.
@preerick
My problem is same with you... Im using remix os now...
Is there a way to make dualboot ?
(10-04-2016, 02:52 AM)aneryan Wrote: @preerick
There is no dual boot mechanism for the pine board ( similar to Grub II ) for the OS versions available atm. Dual boot on the pine board amounts to swapping out the SD card. It is possible to have multiple partitions on a usb stick ( or hdd, ssd ) and have the rootfs on the disk ;  the SD card then boots into the rootfs of choice... a dual boot of sorts.
The only real way to dual-boot at the moment on the pine64 would be via uboot. However, that would require you to choose which OS to boot via the serial console, basically meaning you need to use another computer to connect to the pine64 on bootup, just so you can tell it which OS to boot. Not the most practical option! It will probably be a while before we see anything like BerryBoot or NOOBS for the pine64.
  Background Video Conversion connorja 2 6,251 07-10-2017, 12:14 PM
Last Post: connorja
  Unsupported video mode warning in dmesg utdrmac 1 5,653 02-01-2017, 01:17 PM
Last Post: MarkHaysHarris777
  How to set video output to 4K / UltraHD? Pander 11 21,810 10-20-2016, 08:00 AM
Last Post: Pander
Question Handbrake settings for video conversion on Ubuntu Xenial pelgrim 4 10,814 08-11-2016, 07:35 AM
Last Post: waldo
  Video Drivers Gnx 0 3,378 07-04-2016, 04:48 PM
Last Post: Gnx
  Ubuntu: video lag romangaag 4 10,316 05-03-2016, 10:53 PM
Last Post: romangaag
  Why no DVI-HDMI video? Sequence 1 4,888 05-03-2016, 12:23 PM
Last Post: Luke
