Howto run Linux with resolution other than 1080p
#21
Earlier post deleted ..... I inadvertently put it on the wrong thread....
#22
(05-07-2016, 06:21 PM)baryluk Wrote: Is it possible to output 16:10, 4:3, 5:4, 1:1 resolutions? Something like 2560x1600, 1920x1200, 1600x1200, 1024x768, 1280x1024, 1920x1920, etc
No - check the link above for supported resolutions of the tool. Pine64 supports a subset of those. 4K needs different  kernel because of memory configuration.
I'm looking for a solution to drive 1280x1024 - is the aforementioned a limitation of this specific tool in its current guise or a wider issue (some kind of inability to output that specific resolution or 4:3 at above 800x600)?
Please forgive my n00bn3ss, this is new territory for me.
#23
Please try out anarsoul mainline arch linux build  which may able to support other displayresolution than typical HDMI standard one (720p or 1080p).
Here is the link: https://github.com/anarsoul/linux-build/releases/
#24
(01-15-2018, 11:09 PM)tllim Wrote: Please try out anarsoul mainline arch linux build  which may able to support other displayresolution than typical HDMI standard one (720p or 1080p).
I must apologise, I neglected to note that this was the Pine64 forum (I'm using a Rock64) - is this build of the same modernity with that platform?  I'm keen to try it out if it offers some options.
#25
I tried the Arch distro and I can confirm that 1366x768 is supported just fine ... would that implies it's not a hw issue and a little massaging would allow it on Ubuntu Mate ?
That would be great to add a little more flexibility !!
Thanks anyhow for the hard work.
Lorenzo
#26
(09-30-2018, 12:01 PM)oxomoxo Wrote: I tried the Arch distro and I can confirm that 1366x768 is supported just fine ... would that implies it's not a hw issue and a little massaging would allow it on Ubuntu Mate ?
Lorenzo
Anarsoul's Arch distro is mainline Linux which can support wider range of resolution and also dual display (LCD + HDMI). The Ubuntu Mate using BSP Linux and only support 720P and 1080P output on HDMI port. In near future, developer plan to update Ubuntu Mate to mainline Linux.
#27
It seems that no matter what I do that with 1080p the top, bottom and sides always get cut off with overscan.
#28
I found the problem. It doesn't like monitors that do 1920x1200.
#29
Fantastic work in such a short space of time.
I'm the lord of ocean
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 17,802 03-28-2020, 06:20 PM
Last Post: ty1911
  NEMS Linux for Pine A64 (+) Luke 1 10,629 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,979 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 74,538 01-28-2019, 11:05 PM
Last Post: necrose99
  Real-time linux kernel Artyom 45 127,044 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 10,566 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 9,334 01-30-2018, 10:26 AM
Last Post: Rustproof
  eta linux image?? firosiro 1 6,841 08-03-2017, 10:05 PM
Last Post: pfeerick
  Can I run Alpine Linux on Pine64? douglasmiranda 3 12,558 08-01-2017, 07:20 AM
Last Post: cztian
Music HOWTO: jackd on Pine64 mauritslamers 1 6,406 06-15-2017, 01:21 PM
Last Post: xalius
