Australia/New Zealand Z-Wave module
Video
Hi all
"We currently provide two types of frequency ranges: 868MHz for EU and 908MHz for US. We will produce 921Mhz for Australia/New Zealand region when there is enough request."
Just wanted to register my request for a 921Mhz z-wave module, this would make Pine64 a great choice here. If anyone else is interested please voice your support here too
Cheers
I am in Australia too and have pledged, didn't realise there might be a user issue. Do I have to request a 921 module?
(02-11-2016, 01:16 AM)huckfidle Wrote: I am in Australia too and have pledged, didn't realise there might be a user issue. Do I have to request a 921 module?
The problem is order quantity. If the quantity is small, it is very expensive to build. Just EMI testing alone already several thousand dollars.
+1 for 921MHz version.
+1 for 921MHz version. Aussie here as well. Smile
I will explore on small quantity build.
Ok understand.
What frequency range will be needed for use in Thailand?
(02-16-2016, 07:35 PM)huckfidle Wrote: Ok understand.
It looks like there is a recommendation to go with the EU version in Thailand (it doesn't have its own frequency reserved). Source
(02-15-2016, 01:18 AM)tllim Wrote: I will explore on small quantity build.
Thank you very much, that would be great!
Should we hold off replying to the surveys while you explore this possibility, do you think?
1. The Thailand using EU version.
2. You can hold off for two weeks, I will check with Mitsumi (ZWave model vendor) whether they can provide small volume quantity.
One thing i noticed is that when i picked the z wave module on the Backerkit site, it said it was a 400 series chip but on the Kickstarter project it says z wave Plus which should denote the 500 series chip.  Which one is it?
Question Z-Wave module pinout to make it compatible with Pi b+ ebretteville 59 136,002 07-12-2019, 08:55 AM
Last Post: kris240376
Sad Z-Wave and openzwave+node-openzwave-shared saro 2 10,101 09-01-2017, 05:22 AM
Last Post: saro
  Z-Wave - Full and Low Power Inclusion mode B34N 1 7,244 03-26-2017, 06:03 PM
Last Post: B34N
  KICAD Quick Lib and Module Generator mbt28 1 7,750 02-12-2017, 10:45 PM
  Z Wave Module and still using GPIO bang 2 9,432 01-16-2017, 03:12 AM
Last Post: bang
  Z-Wave US module with adapter aegrotatio 4 12,289 01-08-2017, 12:03 AM
Last Post: aegrotatio
  RaZberry Module (z-wave) need support to get it working! Luxus 13 30,600 11-03-2016, 02:04 AM
Last Post: Luxus
  Z-Wave module problem vintagewaffle 0 3,809 10-26-2016, 10:50 AM
Last Post: vintagewaffle
  [EU] Z-Wave module tutorials? meowbot 2 8,232 09-13-2016, 07:54 PM
Last Post: Ghost
  New module: POT board Crispin 25 63,421 07-12-2016, 08:47 PM
Last Post: khgoh
