Using Bluetooth for Sending serial data
I'm using Ubuntu long sleep OS on pine64+, I'm trying to send serial data from the pine 64+ to the Arduino UNO over bluetooth.
For that i installed Bluez package and when i check for the bluetooth device using "Hcitool dev", its empty.
But i checked the status of bluetooth using "etc/init.d/bluetooth status", the result is,
Quote:● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
   Active: active (running) since Sun 2016-09-11 05:43:23 UTC; 3h 18min ago
     Docs: man:bluetoothd(8)
 Main PID: 7439 (bluetoothd)
   Status: "Running"
   CGroup: /system.slice/bluetooth.service
           └─7439 /usr/lib/bluetooth/bluetoothd
When i add a USB bluetooth adapter to pine 64+, it gets detected and works fine.
I tried this using the procedure given in the following link:
           http://blog.whatgeek.com.pt/2015/09/blue...d-arduino/
Hi Arjun,
I'll be in the same boat as you shortly, as the USB power meter I use when monitoring the pine64 has a bluetooth interface to allow for logging, so I'll be able to add that data I'm currently logging about the board.
In the mean time, it might be worth having a look over this thread, as it seems that xalius was trying to get it to work, and seemed to have some luck in getting it loaded up and working.
(09-11-2016, 03:04 AM)Arjun Wrote: I'm using Ubuntu long sleep OS on pine64+, I'm trying to send serial data from the pine 64+ to the Arduino UNO over bluetooth.
In Bluetoothctl, it is not recognizing the controller.
The result in bluetoothctl is, " No default controller available".
Hurray!!
The problem is solved,, i used "Debian Linux Jessie with Mate GUI Image [20160701] by lenny.raposo with Longsleep kernel", in that image bluetooth problem is already solved.
Now i'm able to send serial data to arduino.
(09-13-2016, 07:44 AM)Arjun Wrote: Hurray!!
I'm absolutely not a distro or kernel builder, so take this for what it is, a probative question based mostly upon ignorance of the work involved, but here goes: Ubuntu is Debian based, so it seems feasible to think someone who knew what they were doing could look at the diffs between the two subsystems and incorporate what works in Debian in the Ubuntu distro?
Would you be able to elaborate a bit further? Are you still using bluez?  What are you using to send/receive data from the Arduino? It looks like anakratis is having trouble, and is on the same distro image... but isn't able to see anything in blueman? I'm interested in knowing what's involved in getting it working also... but from the command line on debian in my case.
No, i didn't use Bluez, i used bluetoothctl.
I also used the same image which he was using, but i followed these steps:
In command line:
  1. I entered "Bluetoothctl", which showed
droot@pine64:/home/debian# bluetoothctl [NEW] Controller 34:C3: D2:E4:0F:E3 pine64 [default] [bluetooth]#
         That proves bluetooth controller is detected.
  2. Then "power on" command inside bluetoothctl
[bluetooth]# power on Changing power on succeeded [CHG] Controller 34:C3: D2:E4:0F:E3 Powered: yes [bluetooth]#
  3. Then "agent on"
[bluetooth]# agent on Agent registered [bluetooth]#
   4. Then "default-agent"
[bluetooth]# default-agent Default agent request successful  [bluetooth]#
   5. Then "scan on" which ll list all surrounding bluetooth devices.
   6. Then for pairing, " pair <dev addr>"
               dev addr will be like "98:01:23:89:56:89"
               If asked for pswd, enter it.
   7. Then "paired-devices" command, will list all the paired devices, here u can cross check the pairing confirmation.
That's it.
Thanks--  very helpful.
Are you sure, after pairing the devices you can connect to the bluetooth module HC- connected to arduino?, bucause I use bluetoothclt on DEBIAN,
but the devices connect for a second, and then it disconnects!
I'm trying to do the same as you but I have no success using blueman, bluez, bluetoothctl Sad
(10-13-2016, 08:01 PM)elpiti Wrote: Are you sure, after pairing the devices you can connect to the bluetooth module HC- connected to arduino?, bucause I use bluetoothclt on DEBIAN,
I'm connecting to HC-05 using this command:
      rfcomm connect hci0 20:16:24:23:69:32 1
  Wifi / Bluetooth Board Update S265 2 7,278 07-30-2020, 04:53 PM
Last Post: S265
Information Howto: Getting Bluetooth (serial console) working on Debian pfeerick 14 48,340 08-19-2019, 04:33 AM
Last Post: Roverius
  RTL8723bs Bluetooth xalius 21 50,780 03-22-2017, 04:53 PM
Last Post: JulianM
  WIFI & Bluetooth? 7777777 14 41,198 12-24-2016, 05:01 AM
Last Post: Toriless
  How can you get the WIFI/Bluetooth module separate? GoZone 8 17,659 07-06-2016, 05:23 PM
Last Post: JasperBrown
  WiFi/BT module, no bluetooth riviera89 5 11,561 06-24-2016, 04:32 PM
Last Post: srinivas.s34@gmail.com
  Board doesn't boot when wifi/Bluetooth connected with Lcd screen Krinilssen 4 11,356 06-16-2016, 07:22 AM
Last Post: Krinilssen
  WIFI/Bluetooth Chipset monmoonmooonmoooon 2 7,964 01-20-2016, 06:02 AM
Last Post: monmoonmooonmoooon
