My Hacky ethernet fix
Love it! Worked on my Pines... 3 done and tested running g stable.
Thank you!
E
Finally prepared a cable with the hacky fix. I'm now the proud user of a Gbe Pine on 100mbit/s.
Thank You for the fix and enabling me to be able to actually use my Pine64. I had given up and stuck it in a drawer for the last 2 months and just chalked this up to a wasting a few dollars. Now it can serve its intended purpose of streaming ESPN3 and live games on Youtube without having to run a cable across the room from my laptop to my tv.
Does anybody have any news about real enabling/use Pine in gigabit speed?
(09-02-2016, 01:52 PM)kermitas Wrote: Does anybody have any news about real enabling/use Pine in gigabit speed?
It seems that all winner won! No new android images, no updates for drivers, no promised 3D HW support on linux, android for pine is abandoned. Now everything is in the hands of the community.
One think to keep in mind that the microSD bandwidth is limited to around 22-23MB/s at best, and the USB 2 ports are limited to 35MB/s. So unless you are transferring from a RAM memory drive or file buffers, there is absolutely no chance of getting anything near to the 125MB/s of GbE... The best results I have seen from my setup are 29-30MB/s upload to the pine64, and 22-25MB/sec download from the pine64, using the Armbian legacy distro with no customisation. This is even in a more 'worst case' scenario when running it with no lithium battery connected (so no battery to smooth any power ripples/fluctuations), an approximately 5 meter Cat5 cable of questionable quality (ripped out of an office somewhere) with self-crimped connectors, and powered via the MicroUSB using a USB powerbank, and no active cooling (no fan, just the heatsinks I put on when I first got it).
It doesn't have the SATA interface or USB3 interfaces that would make the most use of the GbE connection. Having said that, it is certainly capable of double the speeds of a standard 100Mbit link, so that is still nice.
Unfortunately, this doesn't help you guys, as Armbian isn't Android! Sad However, there is no reason to believe that this can't be fixed, as the baring the usual suspects of hardware conflicts (ie auto-negotiation), dodgy power(microUSB/voltage sag) and faulty boards... this is solely a configuration issue, and that is fixable given time for the issue to be reproduced by a developer who can then work on the fix. My experiences with low speed (100Mbit-speeds) on the stock Pine64 Debian build, which can be speed up with some simple settings tweaks, make me believe in most cases this is mainly a software issue.
Gigabyte works stable for me, so this seems like a faulty boards during production.
#19
(09-05-2016, 12:53 PM)ayufan Wrote: Gigabyte works stable for me, so this seems like a faulty boards during production.
Can you share some photos of your board? (for example: by uploading them to Google Drive and share the folder)
Also maybe some details of your board and when did you order it?
#20
That is precisely what this thread is for; please do no start a new one !
http://forum.pine64.org/showthread.php?tid=2036
(please feel free to post pics of your board also, with your data ! )
  Possible to simultaneously connect to ethernet & wi-fi? wahdooyah 3 7,869 01-26-2018, 06:57 PM
Last Post: dkryder
  2nd ethernet in PINE64 with android daniele 2 7,179 12-07-2017, 05:09 AM
Last Post: daniele
  No Ethernet on Andriod rvalecruz 5 15,190 05-05-2017, 01:59 AM
Last Post: Quezbeme
  Lost Ethernet hatman28 13 29,780 11-10-2016, 09:05 PM
Last Post: pfeerick
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 38,183 10-29-2016, 04:31 AM
Last Post: joe
  Android Ethernet Problem a5467021 11 28,252 08-01-2016, 07:41 PM
Last Post: a5467021
  Can we force the ethernet link to 100mbps? moondark 10 24,511 07-26-2016, 10:56 AM
Last Post: kermitas
  Android Issues; 4K, Ethernet, Plex kikootwo 6 12,342 07-10-2016, 12:23 AM
Last Post: yusijs
  Android and Ethernet W1SPY 54 111,224 07-07-2016, 01:48 AM
Last Post: Absum
  Ethernet not working on Android (my dicoverys) Apicalis 9 24,132 06-15-2016, 02:34 AM
Last Post: Apicalis
