root password
What is the password for the root user?
It depends on what image you are using.  The best ones are on the pine64.pro page here: https://www.pine64.pro/downloads/
All of these list the default userid and password.
If you are not using those builds then I am not entirely sure.  I would try "debian" and "password"
These two passwords have been tried out!!
You haven't said which system are you using and what excatlyyou need it for. I think that there is no root password. You have to set it up yourself "sudo passwd root". If you want more help next time please provide more informations.
Sorry, I was confused. The root password is a random thing. You can change it by logging in as the the "debian" user and using "sudo passwd" to change the root. In practice, I have found that is easier (and safer) to work as the debian user and runn sommands as root by running "sudo <command>".
  root running from usb connected ssd locks up system marcelser 0 4,560 11-17-2017, 04:50 PM
Last Post: marcelser
  OMV base on Debian jessie Root Problem ayamy 3 9,480 09-03-2017, 09:21 PM
  resize root partition to max available space SD card can provide bilylilyli 16 35,201 11-18-2016, 07:10 PM
Last Post: pfeerick
  how to use USB hard disk as /(root) hatahata 15 29,197 07-01-2016, 07:09 PM
Last Post: hatahata
Sad How to resize the root partition in order to fully utilize the SD Card MicroDiery 5 12,661 05-24-2016, 05:48 AM
Last Post: Luke
  Debian root's password? rayivy 2 7,188 05-12-2016, 08:59 PM
Last Post: rayivy
  what is the root password for debian? piahoo 5 15,385 04-29-2016, 02:12 PM
Last Post: rhkean
