Ubunu not working anymore
Hello!
I have installed the Ubuntu release a long time ago on my Pine, and everything worked fine. Main use was with an DVB-C stick and tvheadend as a Videoecorder.
I updated the Ubuntu software regularly and the system worked fine.
With the last updated Ubuntu told me to reboot the system, and from that moment on, startup did not complete.
I get an error "[VFE_ERR]Error registering ve412 subdevice No such device!" and "[VFE_ERR]vfe_register check error at input_num = 0 " (and later 1).
My Pine is connected via eth0 - and as I said before this configuration worked for a very long time..."
Help plz!
Thanks!
hi, my response is meant in a friendly spirit of goodwill, and not as a rebuke.
... there are some rules about update and upgrade that must be followed with SBC SoC boards; and I do mean all of them.
1) never update or upgrade unless you have been advised to for a purpose , and then only if there is a 'need'
2) read rule (1) again , and follow it religiously.
3) before updating & upgrading , backup your SD card data , then backup the SD card itself.
4) if it ain't broke, don't fix it.
4b)  or, if it ain't broke, fix it until it is.....   Tongue
The 'weak link' or achilles heel of the PineA64 board ( or the Raspberry PI too ) is the SD card. Its the slow component, its the corruptible component, and its most easily lost.  It is very important to have your SD card backed up for just this situation (and others).
Often, longsleep will be able to tell you what you need to do to fix the card, so don't chuck it.  On the other hand, it is almost always easier and less hassel in the long run to flash a new card and keep smiling... um, computing.
That error does not prevent boot.
Thanks for the reply guys.
@MarkHaysHarris777: well actually I did the upgrade - and as my PINE is connected to the internet I don't think that NOT installing OS updates at all is not a very good option for security reasons.
@longsleep: to be mor exact: U usually connect to the pine64 using ssh and I can't do that because no ports are open on the PINE. Last thing I see at the boot screen is "Press Enter for maintenance or "press Control-D to continue". If I press control+D it says "sulogin cannot read /dev/tty1 permission denied", and after a while I get "Press Enter for maintenance (or press Control-D to continue):" again.
If I press enter I get a root command prompt, still no ports open....
Stefan
Well most likely the filesystem is broken. Best try to fix it with another Linux PC.
This may or may not be relevant, but I've seen the Press Enter for Maintenance prompt before as well, and got nervous. After a very long time (~30 minutes- give or take) the system did boot on it's own. In my case, it happened when CIFS shares and an external HD listed in /etc/fstab were not available. Do you have any file systems that Ubuntu might be searching for?
Well, checking the filesystem on another linux system didn't lead to a solution.
googled for VFE_ERR and found out that it comes from a "sunxi Camera Interface driver" - I'm pretty sure I would'nt need that because I have no cam installed - so is there a chance to remove this driver?
(08-23-2016, 08:56 AM)CrazyBird Wrote: Well, checking the filesystem on another linux system didn't lead to a solution.
On the other linux system did you mount the SD card and run fsck on both partitions... but especially the mmcblk0p2 ?
Just rechecked both partitions - both are allright according to fsck.
Still, the issue remains an I'm not able to use my PINE with ubuntu.
Another question: i can't find a boot.log on the system...
Thanks again for any help
Stefan
Here my dmesg - output. Hope that helps:
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.65-7-pine64-longsleep (longsleep@mose2) (gcc version 5.3.1 20160413 (Ubuntu/Linaro 5.3.1-14ubuntu2) ) #28 SMP PREEMPT Sat Apr 23 20:13:25 CEST 2016
[    0.000000] CPU: AArch64 Processor [410fd034] revision 4
[    0.000000] Machine: sun50iw1p1
[    0.000000] cma: CMA: reserved 64 MiB at bc000000
[    0.000000] On node 0 totalpages: 520192
[    0.000000]   DMA zone: 7112 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 520192 pages, LIFO batch:31
[    0.000000] script_init enter!
[    0.000000] script buffer is NULL!
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] PERCPU: Embedded 12 pages/cpu @ffffffc07af92000 s19712 r8192 d21248 u49152
[    0.000000] pcpu-alloc: s19712 r8192 d21248 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 513080
[    0.000000] Kernel command line: console=tty0 console=ttyS0,115200n8 no_console_suspend earlycon=uart,mmio32,0x01c28000 mac_addr=8e:21:0d:2e:ad:67 root=/dev/mmcblk0p2 ro rootwait
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 2032MB = 2032MB total
[    0.000000] Memory: 1969976k/1969976k available, 110792k reserved
[    0.000000] Virtual kernel memory layout:
                  vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000   (245759 MB)
                  vmemmap : 0xffffffbc00e38000 - 0xffffffbc02a00000   (    27 MB)
                  modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64 MB)
                  memory  : 0xffffffc000000000 - 0xffffffc07f000000   (  2032 MB)
                    .init : 0xffffffc000957000 - 0xffffffc0009d0d00   (   488 kB)
                    .text : 0xffffffc000080000 - 0xffffffc0009569b4   (  9051 kB)
                    .data : 0xffffffc0009d1000 - 0xffffffc000b27168   (  1369 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] allocated 8388608 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    7.295473] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    7.295504] pid_max: default: 32768 minimum: 301
[    7.295608] Security Framework initialized
[    7.295643] AppArmor: AppArmor initialized
[    7.295687] Mount-cache hash table entries: 256
[    7.306106] Initializing cgroup subsys memory
[    7.306166] Initializing cgroup subsys devices
[    7.306183] Initializing cgroup subsys freezer
[    7.306199] Initializing cgroup subsys blkio
[    7.306214] Initializing cgroup subsys perf_event
[    7.306235] Initializing cgroup subsys hugetlb
[    7.306285] ftrace: allocating 25847 entries in 101 pages
[    7.336424] CPU0: update cpu_power 1968128
[    7.336458] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counters available
[    7.337381] virtual base = 0xffffff800000a000.
[    7.337401] gicd_base = 0xffffff800000c000.
[    7.337414] gicc_base = 0xffffff800000e000.
[    7.337990] CPU1: Booted secondary processor
[    7.338013] CPU1: update cpu_power 1968128
[    7.340615] CPU2: Booted secondary processor
[    7.340627] CPU2: update cpu_power 1968128
[    7.344734] CPU3: Booted secondary processor
[    7.344745] CPU3: update cpu_power 1968128
[    7.344823] Brought up 4 CPUs
[    7.344897] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    7.345428] devtmpfs: initialized
[    7.350214] atomic64 test passed
[    7.350236] pinctrl core: initialized pinctrl subsystem
[    7.353212] NET: Registered protocol family 16
[    7.353522] script_sysfs_init success
[    7.354363] dump_class_init,806, success
[    7.355000] vdso: 2 pages (1 code, 1 data) at base ffffffc0009d9000
[    7.355033] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    7.356342] software IO TLB [mem 0xb8800000-0xb8c00000] (4MB) mapped at [ffffffc077800000-ffffffc077bfffff]
[    7.357270] DMA: preallocated 256 KiB pool for atomic allocations
[    7.357451] Serial: AMBA PL011 UART driver
[    7.357826] axp81x_board_init: axp regl_devs num = 23
[    7.358040] pll_audio-set_default_rate=24576000 success!
[    7.358071] pll_video0-set_default_rate=297000000 success!
[    7.358154] pll_video1-set_default_rate=297000000 success!
[    7.358223] pll_de-set_default_rate=297000000 success!
[    7.358955] de-set_default_source=pll_de success!
[    7.358972] de-set_default_rate=297000000 success!
[    7.359025] tcon0-set_default_source=pll_mipi success!
[    7.359068] tcon1-set_default_source=pll_video0 success!
[    7.359299] hdmi-set_default_source=pll_video0 success!
[    7.361834] sun50i-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[    7.362083] [sun50iw1p1_pinctrl_probe][838]
[    7.363832] sun50i-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    7.365122] sunxi hwspinlock vbase:0xffffff800005c000
[    7.375044] sunxi_chipid_probe,150: soc bin:0
[    7.392190] bio: create slab <bio-0> at 0
[    7.392611] pwm module init!
[    7.394913] SCSI subsystem initialized
[    7.395401] usbcore: registered new interface driver usbfs
[    7.395518] usbcore: registered new interface driver hub
[    7.395655] usbcore: registered new device driver usb
[    7.396945] Linux video capture interface: v2.00
[    7.397881] [ARISC] :sunxi-arisc driver v1.10
[    7.409676] [ARISC] :sunxi-arisc driver v1.10 startup succeeded
[    7.410075] Advanced Linux Sound Architecture Driver Initialized.
[    7.410647] NetLabel: Initializing
[    7.410661] NetLabel:  domain hash size = 128
[    7.410673] NetLabel:  protocols = UNLABELED CIPSOv4
[    7.410719] NetLabel:  unlabeled traffic allowed by default
[    7.410967] [pm]aw_pm_init!
[    7.411050] rtc physical base = 0x0000000001f00000 .
[    7.411094] np name = /soc@01c00000/rtc@01f00000.
[    7.411110] base = ffffff8000070100, len = 4.
[    7.411123] pmu name: pmu0 .
[    7.411168] pmu0_enable = 0x1.
[    7.411181] pmux_id = 0x6.
[    7.411193] pmux_twi_id = 0x1.
[    7.411205] pmux_twi_addr = 0x34.
[    7.411216] pmu name: pmu1 .
[    7.411273] Warning: can not find np for pmu1.
[    7.411508] add_sys_pwr_dm: get ldo name  for id: vcc-lpddr failed
[    7.411674] after inited: sys_mask config = 0x4a55.
[    7.411707] Warning: can not find np for dynamic_standby_para.
[    7.411839] [pm]valid
[    7.411849] [pm]valid
[    7.411859] Notice: sun9i&sun8iw5&sun50i not need support normal standby, change to super standby.
[    7.412057] Switching to clocksource arch_sys_counter
[    7.422607] AppArmor: AppArmor Filesystem Enabled
[    7.434978] NET: Registered protocol family 2
[    7.435625] TCP established hash table entries: 16384 (order: 6, 262144 bytes)
[    7.435884] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    7.436168] TCP: Hash tables configured (established 16384 bind 16384)
[    7.436253] TCP: reno registered
[    7.436270] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    7.436332] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    7.436577] NET: Registered protocol family 1
[    7.436847] RPC: Registered named UNIX socket transport module.
[    7.436865] RPC: Registered udp transport module.
[    7.436879] RPC: Registered tcp transport module.
[    7.436892] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    7.437056] Unpacking initramfs...
[    7.480683] Freeing initrd memory: 1048K (ffffffc075dad000 - ffffffc075eb3000)
[    7.481438] kvm [1]: Using HYP init bounce page @b9bdd000
[    7.481895] kvm [1]: interrupt-controller@1c84000 IRQ25
[    7.482245] kvm [1]: timer IRQ27
[    7.482264] kvm [1]: Hyp mode initialized successfully
[    7.483622] lock super standby defaultly!
[    7.483648] lookup_scene_lock_name: new scene lock super_standby
[    7.483664] scene_lock_init name=super_standby
[    7.483679] scene_lock: super_standby, type 5, count 1
[    7.484349] audit: initializing netlink socket (disabled)
[    7.484399] type=2000 audit(0.180:1): initialized
[    7.485354] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    7.485815] VFS: Disk quotas dquot_6.5.2
[    7.485931] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    7.486352] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    7.486753] NFS: Registering the id_resolver key type
[    7.486803] Key type id_resolver registered
[    7.486817] Key type id_legacy registered
[    7.486837] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    7.486986] NTFS driver 2.1.30 [Flags: R/W].
[    7.487246] fuse init (API version 7.22)
[    7.487641] msgmni has been set to 3977
[    7.488457] io scheduler noop registered
[    7.488473] io scheduler deadline registered
[    7.488510] io scheduler cfq registered (default)
[    7.489316] [DISP]disp_module_init
[    7.489869] [DISP] boot_disp:0x40a
[    7.490442] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[    7.490602] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[    7.490761] [DISP] disp_sys_script_get_item,line:193:of_find_compatible_node allwinner,sunxi-lcd1 fail
[    7.491894] [DISP] fb_base:0x47400000
[    7.499459] [DISP] Fb_map_kernel_logo,line:885:this is not a bmp picture.
[    7.529339] Console: switching to colour frame buffer device 240x67
[    7.558291] [DISP]disp_module_init finish
[    7.558816] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[    7.558971] sw_console_setup()1173 - console setup baud 115200 parity n bits 8, flow n
[    8.519619] console [ttyS0] enabled
[    8.524073] uart1: ttyS1 at MMIO 0x1c28400 (irq = 33) is a SUNXI
[    8.531099] uart2: ttyS2 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    8.538211] uart3: ttyS3 at MMIO 0x1c28c00 (irq = 35) is a SUNXI
[    8.545286] uart4: ttyS4 at MMIO 0x1c29000 (irq = 36) is a SUNXI
[    8.552484] misc dump reg init
[    8.556234] [drm] Initialized drm 1.1.0 20060810
[    8.564893] loop: module loaded
[    8.568662] sunxi-bt bt.27: Missing bt_power.
[    8.573541] sunxi-bt bt.27: bt_power_name ((null))
[    8.578883] sunxi-bt bt.27: io_regulator_name (vcc-wifi-io)
[    8.585133] sunxi-bt bt.27: bt_rst gpio=356  mul-sel=1  pull=-1  drv_level=-1  data=0
[    8.593903] sunxi-bt bt.27: clk not config
[    8.598600] sunxi-bt bt.27: block state already is 1
[    8.604452] sunxi-wlan wlan.26: wlan_busnum (1)
[    8.609502] sunxi-wlan wlan.26: Missing wlan_power.
[    8.614946] sunxi-wlan wlan.26: wlan_power_name ((null))
[    8.620867] sunxi-wlan wlan.26: io_regulator_name (vcc-wifi-io)
[    8.627494] sunxi-wlan wlan.26: wlan_regon gpio=354  mul-sel=1  pull=-1  drv_level=-1  data=0
[    8.637033] sunxi-wlan wlan.26: wlan_hostwake gpio=355  mul-sel=6  pull=-1  drv_level=-1  data=0
[    8.646851] sunxi-wlan wlan.26: clk not config
[    8.652458] tun: Universal TUN/TAP device driver, 1.6
[    8.658090] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    8.665689] WARNING: Get ephy clock is failed
[    8.671170] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    8.678612] get ehci0-controller drv_vbus_gpio is fail
[    8.684351] get ehci0-controller, regulator_io is no nocare
[    8.690611] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000bd16a8, 0x:ffffff80000ae000, irq_no:68
[    8.704141] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    8.714252] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[    8.724152] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0004bf654
[    8.750362] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[    8.758125] ehci_irq: highspeed device connect
[    8.763675] hub 1-0:1.0: USB hub found
[    8.773878] hub 1-0:1.0: 1 port detected
[    8.784289] scene_lock_init name=ehci_standby
[    8.795104] get ehci1-controller drv_vbus_gpio is fail
[    8.806664] get ehci1-controller, regulator_io is no nocare
[    8.818705] [sunxi-ehci1]: probe, pdev->name: 1c1b000.ehci1-controller, sunxi_ehci: 0xffffffc000bd18f8, 0x:ffffff80000b6000, irq_no:6a
[    8.838166] sunxi-ehci 1c1b000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    8.854388] sunxi-ehci 1c1b000.ehci1-controller: new USB bus registered, assigned bus number 2
[    8.870392] sunxi-ehci 1c1b000.ehci1-controller: irq 106, io mem 0xffffffc0004bf654
[    8.897961] sunxi-ehci 1c1b000.ehci1-controller: USB 0.0 started, EHCI 1.00
[    8.911836] ehci_irq: highspeed device connect
[    8.923511] hub 2-0:1.0: USB hub found
[    8.933887] hub 2-0:1.0: 1 port detected
[    8.944564] scene_lock_init name=ehci_standby
[    8.955893] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    8.969199] get ohci0-controller drv_vbus_gpio is fail
[    8.981252] get ohci0-controller, regulator_io is no nocare
[    8.993749] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000bd1208
[    9.010436] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    9.026454] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[    9.042353] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0x6a626e6b61ff726b
[    9.094766] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[    9.118903] hub 3-0:1.0: USB hub found
[    9.129327] hub 3-0:1.0: 1 port detected
[    9.140008] scene_lock_init name=ohci_standby
[    9.151076] get ohci1-controller drv_vbus_gpio is fail
[    9.162893] get ohci1-controller, regulator_io is no nocare
[    9.175236] [sunxi-ohci1]: probe, pdev->name: 1c1b000.ohci1-controller, sunxi_ohci: 0xffffffc000bd1458
[    9.191730] sunxi-ohci 1c1b000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    9.207551] sunxi-ohci 1c1b000.ohci1-controller: new USB bus registered, assigned bus number 4
[    9.223285] sunxi-ohci 1c1b000.ohci1-controller: irq 107, io mem 0x6a626e6b61ff726b
[    9.295977] hub 4-0:1.0: USB hub found
[    9.306529] hub 4-0:1.0: 1 port detected
[    9.317324] scene_lock_init name=ohci_standby
[    9.329017] usbcore: registered new interface driver usb-storage
[    9.342043] ehci_irq: highspeed device disconnect
[    9.353632] ohci_irq: fullspeed or lowspeed device connect
[    9.366190] usbcore: registered new interface driver ums-alauda
[    9.379348] usbcore: registered new interface driver ums-cypress
[    9.392490] usbcore: registered new interface driver ums-datafab
[    9.405549] usbcore: registered new interface driver ums_eneub6250
[    9.418728] usbcore: registered new interface driver ums-freecom
[    9.431690] usbcore: registered new interface driver ums-isd200
[    9.444501] usbcore: registered new interface driver ums-jumpshot
[    9.457499] usbcore: registered new interface driver ums-karma
[    9.470191] usbcore: registered new interface driver ums-onetouch
[    9.483125] usbcore: registered new interface driver ums-realtek
[    9.495870] usbcore: registered new interface driver ums-sddr09
[    9.508426] usbcore: registered new interface driver ums-sddr55
[    9.520881] usbcore: registered new interface driver ums-usbat
[    9.533306] usbcore: registered new interface driver usbserial
[    9.545538] usbcore: registered new interface driver usbserial_generic
[    9.558454] usbserial: USB Serial support registered for generic
[    9.571164] mousedev: PS/2 mouse device common for all mice
[    9.583555] input: sunxi-keyboard as /devices/virtual/input/input0
[    9.596747] sunxi-rtc 1f00000.rtc: rtc core: registered rtc-sunxi as rtc0
[    9.609842] sunxi-rtc 1f00000.rtc: RTC enabled
[    9.656251] input: axp81x-supplyer as /devices/platform/axp81x_board/axp81x-supplyer.47/input/input1
[    9.678715] sunxi budget cooling probe start !
[    9.689305] CPU freq cooling register Success
[    9.699753] CPU hotplug cooling register Success
[    9.710517] CPU budget cooling register Success
[    9.721502] sunxi gpu cooling probe start !
[    9.731663] CPU gpu cooling register Success
[    9.744768] cpuidle: using governor ladder
[    9.754129] cpuidle: using governor menu
[    9.764074] sunxi-mmc 1c0f000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Apr 23 2016 at 17:56:40
[    9.782284] sunxi-mmc 1c0f000.sdmmc: regulator prop vmmc,str none
[    9.793783] sunxi-mmc 1c0f000.sdmmc: regulator prop vqmmc,str none
[    9.805310] sunxi-mmc 1c0f000.sdmmc: regulator prop vdmmc,str vcc-sdc
[    9.817123] sunxi-mmc 1c0f000.sdmmc: No vmmc regulator found
[    9.828006] sunxi-mmc 1c0f000.sdmmc: No vqmmc regulator found
[    9.839353] sunxi-mmc 1c0f000.sdmmc: Got CD GPIO #166.
[    9.849812] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[    9.865542] sunxi-mmc 1c0f000.sdmmc: no vqmmc,Check if there is regulator
[    9.891860] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[    9.921338] sunxi-mmc 1c0f000.sdmmc: base:0xffffff80000ca000 irq:92
[    9.921343] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
[    9.945607] sunxi-mmc 1c10000.sdmmc: SD/MMC/SDIO Host Controller Driver(v0.20 2015-7-13 16:28) Compiled in Apr 23 2016 at 17:56:40
[    9.963479] sunxi-mmc 1c10000.sdmmc: Can't get vmmc regulator string
[    9.975339] sunxi-mmc 1c10000.sdmmc: Can't get vqmmc regulator string
[    9.987254] sunxi-mmc 1c10000.sdmmc: Can't get vdmmc regulator string
[    9.999102] get() with no identifier
[   10.007736] get() with no identifier
[   10.016290] get() with no identifier
[   10.020524] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.021336] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
[   10.021352] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.023732] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.025858] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.026667] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.027476] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.028285] sunxi-mmc 1c0f000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
[   10.028913] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.028953] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.031324] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   10.170862] sunxi-mmc 1c10000.sdmmc: No vmmc regulator found
[   10.181320] sunxi-mmc 1c10000.sdmmc: No vqmmc regulator found
[   10.182219] mmc0: SD Status: Invalid Allocation Unit size.
[   10.183857] mmc0: host does not support reading read-only switch. assuming write-enable.
[   10.185552] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.185591] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   10.185685] sunxi-mmc 1c0f000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   10.185704] mmc0: new high speed SDXC card at address 0001
[   10.274044] mmcblk0: mmc0:0001 00000 59.6 GiB
[   10.274143] sunxi-mmc 1c10000.sdmmc: No vdmmc regulator found
[   10.295069] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.295935]  mmcblk0: p1 p2
[   10.319055] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   10.344448] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.373968] sunxi-mmc 1c10000.sdmmc: base:0xffffff80000d2000 irq:93
[   10.374765] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.375572] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   10.375587] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.377959] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.379774] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   10.380580] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.381384] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.382189] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.382993] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[   10.383800] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.384607] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.385412] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.386216] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 55, RTO !!
[   10.386232] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   10.387064] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 1, RTO !!
[   10.387079] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm OD pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[   10.595336] input: Logitech USB Receiver as /devices/soc.0/1c1b000.ohci1-controller/usb4/4-1/4-1:1.0/input/input2
[   10.611763] hid-generic 0003:046D:C52B.0001: input: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-sunxi-ohci-1/input0
[   10.634936] input: Logitech USB Receiver as /devices/soc.0/1c1b000.ohci1-controller/usb4/4-1/4-1:1.1/input/input3
[   10.651604] hid-generic 0003:046D:C52B.0002: input: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-sunxi-ohci-1/input1
[   10.676087] hid-generic 0003:046D:C52B.0003: device has no listeners, quitting
[   10.689402] usbcore: registered new interface driver usbhid
[   10.700792] usbhid: USB HID core driver
[   10.711521] usbcore: registered new interface driver snd-usb-audio
[   10.725611] sndhdmi sound.7:  sndhdmi <-> 1c22800.daudio mapping ok
[   10.738826] TCP: cubic registered
[   10.747739] NET: Registered protocol family 10
[   10.758330] sit: IPv6 over IPv4 tunneling driver
[   10.769071] NET: Registered protocol family 17
[   10.779014] Key type dns_resolver registered
[   10.788754] Registering SWP/SWPB emulation handler
[   10.799778] [DISP] boot_disp:0x40a
[   10.809262] [HDMI] power vcc-hdmi-33
[   10.818585] [HDMI] cec support = 0
[   11.079817] [DISP] disp_device_attached,line:94:attched ok, mgr0<-->device1, type=4
[   11.094194] sunxi-rtc 1f00000.rtc: setting system clock to 2010-01-01 00:00:08 UTC (1262304008)
[   11.109796] input: sunxi-ths as /devices/virtual/input/input4
[   11.121636] thermal thermal_zone0: failed to read out thermal zone 0
[   11.134342] ALSA device list:
[   11.142898]   #0: sndhdmi
[   11.151342] Freeing unused kernel memory: 484K (ffffffc000957000 - ffffffc0009d0000)
[   11.574443] [ehci0-controller]: sunxi_usb_disable_ehci
[   11.585629] [sunxi-ehci0]: remove, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000bd16a8
[   11.601615] scene_lock_destroy name=ehci_standby
[   11.612317] sunxi-ehci 1c1a000.ehci0-controller: remove, state 1
[   11.624654] usb usb1: USB disconnect, device number 1
[   11.635997] usb 1-1: USB disconnect, device number 2
[   11.649319] sunxi-ehci 1c1a000.ehci0-controller: USB bus 1 deregistered
[   11.662440] ohci_irq: fullspeed or lowspeed device connect
[   11.674368] [ohci0-controller]: sunxi_usb_disable_ohci
[   11.685799] [sunxi-ohci0]: remove, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000bd1208
[   11.701962] scene_lock_destroy name=ohci_standby
[   11.712856] sunxi-ohci 1c1a000.ohci0-controller: remove, state 84
[   11.889381] usb usb3: USB disconnect, device number 1
[   12.007933] sunxi-ohci 1c1a000.ohci0-controller: USB bus 3 deregistered
[   12.021135] [ehci0-controller]: sunxi_usb_enable_ehci
[   12.032580] [sunxi-ehci0]: probe, pdev->name: 1c1a000.ehci0-controller, sunxi_ehci: 0xffffffc000bd16a8, 0x:ffffff80000ae000, irq_no:68
[   12.051958] sunxi-ehci 1c1a000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[   12.067992] sunxi-ehci 1c1a000.ehci0-controller: new USB bus registered, assigned bus number 1
[   12.083940] sunxi-ehci 1c1a000.ehci0-controller: irq 104, io mem 0xffffffc0006b0664
[   12.115636] sunxi-ehci 1c1a000.ehci0-controller: USB 0.0 started, EHCI 1.00
[   12.129215] ehci_irq: highspeed device connect
[   12.140595] hub 1-0:1.0: USB hub found
[   12.150733] hub 1-0:1.0: 1 port detected
[   12.161300] scene_lock_init name=ehci_standby
[   12.172209] [ohci0-controller]: sunxi_usb_enable_ohci
[   12.183752] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[   12.183847] [sunxi-ohci0]: probe, pdev->name: 1c1a000.ohci0-controller, sunxi_ohci: 0xffffffc000bd1208
[   12.183902] sunxi-ohci 1c1a000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[   12.183923] sunxi-ohci 1c1a000.ohci0-controller: new USB bus registered, assigned bus number 3
[   12.183960] sunxi-ohci 1c1a000.ohci0-controller: irq 105, io mem 0xffffffc0006b0664
[   12.238229] hub 3-0:1.0: USB hub found
[   12.238242] hub 3-0:1.0: 1 port detected
[   12.238375] scene_lock_init name=ohci_standby
[   12.295565] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[   12.382328] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[   12.469925] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[   12.733066] systemd[1]: System time before build time, advancing clock.
[   12.853050] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[   12.880122] systemd[1]: Detected architecture arm64.
[   12.913608] systemd[1]: Set hostname to <Corellia>.
[   13.513359] systemd[1]: [/etc/systemd/system/eth0-mackeeper.service:6] Unknown lvalue 'After' in section 'Service'
[   13.531564] systemd[1]: [/etc/systemd/system/eth0-mackeeper.service:7] Unknown lvalue 'After' in section 'Service'
[   13.580706] systemd[1]: Listening on udev Kernel Socket.
[   13.611435] systemd[1]: PNFS blkmaping enablement. is not active.
[   13.640888] systemd[1]: Dependency failed for pNFS block layout mapping daemon.
[   13.670424] systemd[1]: nfs-blkmap.service: Job nfs-blkmap.service/start failed with result 'dependency'.
[   13.687901] systemd[1]: Listening on udev Control Socket.
[   13.719939] systemd[1]: Listening on Syslog Socket.
[   13.749296] systemd[1]: Listening on Journal Socket.
[   13.778782] systemd[1]: Listening on fsck to fsckd communication Socket.
[   13.808267] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[   13.837706] systemd[1]: Reached target Encrypted Volumes.
[   13.867302] systemd[1]: Listening on Journal Socket (/dev/log).
[   13.897109] systemd[1]: Created slice System Slice.
[   13.928143] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[   13.967630] systemd[1]: Mounting POSIX Message Queue File System...
[   13.997159] systemd[1]: Starting Remount Root and Kernel File Systems...
[   14.035078] systemd[1]: Created slice system-serial\x2dgetty.slice.
[   14.066244] systemd[1]: Starting Journal Service...
[   14.095285] systemd[1]: Starting Nameserver information manager...
[   14.154608] systemd[1]: Started Braille Device Support.
[   14.171534] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   14.194823] systemd[1]: Mounting Huge Pages File System...
[   14.238423] systemd[1]: Starting Load Kernel Modules...
[   14.272657] systemd[1]: Starting Set console keymap...
[   14.300425] systemd[1]: Reached target Swap.
[   14.330320] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[   14.348578] ppdev: user-space parallel port driver
[   14.366056] systemd[1]: Reached target User and Group Name Lookups.
[   14.399008] systemd[1]: Created slice User and Session Slice.
[   14.428253] systemd[1]: Reached target Slices.
[   14.459324] systemd[1]: Mounting RPC Pipe File System...
[   14.487453] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   14.518436] systemd[1]: Mounting NFSD configuration filesystem...
[   14.548039] systemd[1]: Mounting Debug File System...
[   14.579717] systemd[1]: Mounted NFSD configuration filesystem.
[   14.599063] systemd[1]: Mounted RPC Pipe File System.
[   14.635012] systemd[1]: Mounted Huge Pages File System.
[   14.664450] systemd[1]: Mounted Debug File System.
[   14.693998] systemd[1]: Mounted POSIX Message Queue File System.
[   14.723892] systemd[1]: Started Journal Service.
[   14.851708] cfg80211: Calling CRDA to update world regulatory domain
[   14.998337] RTL871X: module init start
[   15.008770] RTL871X: rtl8723bs v4.3.16_13854.20150410_BTCOEX20150119-5844
[   15.022214] RTL871X: build time: Apr 23 2016 17:32:18
[   15.033694] RTL871X: rtl8723bs BT-Coex version = BTCOEX20150119-5844
[   15.046687] sunxi-wlan wlan.26: bus_index: 1
[   15.057594] sunxi-wlan wlan.26: check wlan io_regulator voltage: 1800000
[   15.134752] systemd-journald[903]: Received request to flush runtime journal from PID 1
[   15.166135] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[   15.184330] sunxi-mmc 1c10000.sdmmc: no vqmmc,Check if there is regulator
[   15.199469] RTL871X: module init ret=0
[   15.225130] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   15.255443] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   15.275121] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[   15.287861] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   15.307838] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[   15.329080] sunxi-mmc 1c10000.sdmmc: smc 1 p1 err, cmd 8, RTO !!
[   15.342291] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing LEGACY(SDR12) dt B
[   15.372317] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 400000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   15.390859] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 1 timing SD-HS(SDR25) dt B
[   15.410373] sunxi-mmc 1c10000.sdmmc: sdc set ios: clk 50000000Hz bm PP pm ON vdd 16 width 4 timing SD-HS(SDR25) dt B
[   15.430408] mmc1: new high speed SDIO card at address 0001
[   15.476829] RTL871X: rtw_ndev_init(wlan0)
[   15.478008] RTL871X: rtw_ndev_init(wlan1)
[   16.410028] sunxi cedar version 0.1
[   16.410230] [cedar]: install start!!!
[   16.410337] ycy the get irq is 90
[   16.411039] ycy clk_bass_vir 0x18  is ffffff8002892018, the value:3006207
[   16.411050] ycy clk_bass_vir 0x13c  is ffffff800289213c, the value:0
[   16.411056] ycy clk_bass_vir 0x64  is ffffff8002892064, the value:601810
[   16.411060] ycy clk_bass_vir 0x2c4  is ffffff80028922c4, the value:601c10
[   16.411065] ycy clk_bass_vir 0x100  is ffffff8002892100, the value:0
[   16.411068] [cedar]: install end!!!
[   16.534693] Mali: Set gpu frequency to 408 MHz
[   16.534754] Mali: Init Mali gpu clocks successfully
[   16.545619] gpu cooling callback register Success
[   16.550499] Mali: Mali device driver loaded
[   16.552425] [VFE]cci probe end cci_sel = 0!
[   16.552737] [VFE]cci_init end
[   16.703602] cfg80211: World regulatory domain updated:
[   16.703606] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[   16.703614] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   16.703617] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[   16.703619] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[   16.703622] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   16.703624] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   16.703627] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm)
[   16.703629] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[   16.703632] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[   16.975938] [VFE]Welcome to Video Front End driver
[   16.976306] [VFE]csi probe end csi_sel = 0!
[   16.978074] [VFE]csi_init end
[   16.978671] [VFE]isp probe start isp_sel = 0!
[   16.986027] [ISP] isp platform_id = 3!
[   16.986049] [VFE]isp probe end isp_sel = 0!
[   16.988137] [VFE]sunxi_isp_platform_register end
[   16.988732] [VFE]mipi probe start mipi_sel = 0!
[   16.988763] [VFE]mipi probe end mipi_sel = 0!
[   16.989293] [VFE]mipi_init end
[   16.989311] [VFE]flash_init end
[   16.990433] [VFE]pdev->id = 0
[   16.990447] [VFE]dev->vip_sel = 0
[   16.990475] [VFE_WARN]fetch csi0_dev0_twi_id from device_tree failed
[   16.990513] [VFE_WARN]fetch csi0_dev0_afvdd from device_tree failed
[   16.990521] [VFE_WARN]fetch csi0_dev0_afvdd_vol from device_tree failed
[   16.990531] [VFE_WARN]fetch csi0_dev0_power_en from device_tree failed
[   16.990579] [VFE_WARN]fetch csi0_dev0_flash_en from device_tree failed
[   16.990587] [VFE_WARN]fetch csi0_dev0_flash_mode from device_tree failed
[   16.990599] [VFE_WARN]fetch csi0_dev0_af_pwdn from device_tree failed
[   16.990621] [VFE_WARN]fetch csi0_dev1_twi_id from device_tree failed
[   16.990649] [VFE_WARN]fetch csi0_dev1_afvdd from device_tree failed
[   16.990655] [VFE_WARN]fetch csi0_dev1_afvdd_vol from device_tree failed
[   16.990662] [VFE_WARN]fetch csi0_dev1_power_en from device_tree failed
[   16.990684] [VFE_WARN]fetch csi0_dev1_flash_en from device_tree failed
[   16.990692] [VFE_WARN]fetch csi0_dev1_flash_mode from device_tree failed
[   16.990703] [VFE_WARN]fetch csi0_dev1_af_pwdn from device_tree failed
[   16.990723] [VFE]fetch rear sensor list info start!
[   16.990727] [VFE]Fetch sensor list form"/system/etc/hawkview/sensor_list_cfg.ini"
[   17.031128] [vfe_warn]open file failed!
[   17.046010] gpu cooling callback set freq limit 0
[   17.141323] [VFE]fetch rear sensor list info end!
[   17.141377] [VFE]fetch front sensor list info start!
[   17.141381] [VFE]Fetch sensor list form"/system/etc/hawkview/sensor_list_cfg.ini"
[   17.177984] [vfe_warn]open file failed!
[   17.212472] sunxi-bt bt.27: set block: 0
[   17.212623] sunxi-bt bt.27: check bluetooth io_regulator voltage: 1800000
[   17.216017] [VFE]fetch front sensor list info end!
[   17.216223] [VFE_WARN]os_gpio_request failed, gpio=129, ret=0xfffffff0, -16
[   17.216595] [VFE]vfe_init end
[   17.222914] [VFE]probe_work_handle start!
[   17.223066] [VFE]vfe_runtime_resume
[   17.235112] [VFE]..........................vfe clk open!.......................
[   17.235128] [VFE_WARN]vfe dphy clock is null
[   17.235152] [VFE]v4l2 subdev register input_num = 0
[   17.235293] [VFE]vfe sensor detect start! input_num = 0
[   17.235303] [VFE_WARN]NOT found this item:  hm5065, you can add this sensor in the sensor_list_t!
[   17.235309] [VFE]Sub device register "hm5065" i2c_addr = 0x3e start!
[   17.235315] [VFE_ERR]Error registering v4l2 subdevice No such device!
[   17.250383] [VFE_ERR]vfe sensor register check error at input_num = 0
[   17.263395] [VFE]v4l2 subdev register input_num = 1
[   17.263449] axp81x_aldo1: Failed to create debugfs directory
[   17.263462] axp81x_dldo3: Failed to create debugfs directory
[   17.263474] axp81x_eldo3: Failed to create debugfs directory
[   17.263484] axp81x_aldo1: Failed to create debugfs directory
[   17.263489] [VFE]vfe sensor detect start! input_num = 1
[   17.263499] [VFE_WARN]NOT found this item:  gc2145, you can add this sensor in the sensor_list_t!
[   17.263504] [VFE]Sub device register "gc2145" i2c_addr = 0x78 start!
[   17.263511] [VFE_ERR]Error registering v4l2 subdevice No such device!
[   17.276450] [VFE_ERR]vfe sensor register check error at input_num = 1
[   17.289671] [VFE]V4L2 device registered as (null)
[   17.289708] [VFE]vfe_runtime_suspend
[   17.289713] [VFE]..........................vfe clk close!.......................
[   17.295883] [VFE]probe_work_handle end!
[  103.590737] type=1400 audit(1472108337.853:2): apparmor="STATUS" operation="profile_load" name="/usr/lib/snapd/snap-confine" pid=2552 comm="apparmor_parser"
[  103.631568] type=1400 audit(1472108337.893:3): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=2549 comm="apparmor_parser"
[  103.631987] type=1400 audit(1472108337.893:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=2549 comm="apparmor_parser"
[  103.632400] type=1400 audit(1472108337.893:5): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-helper" pid=2549 comm="apparmor_parser"
[  103.632789] type=1400 audit(1472108337.893:6): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=2549 comm="apparmor_parser"
[  103.645443] type=1400 audit(1472108337.903:7): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm-guest-session" pid=2548 comm="apparmor_parser"
[  103.645952] type=1400 audit(1472108337.903:8): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=2548 comm="apparmor_parser"
[  103.669872] type=1400 audit(1472108337.933:9): apparmor="STATUS" operation="profile_load" name="/usr/sbin/cups-browsed" pid=2554 comm="apparmor_parser"
[  103.680977] type=1400 audit(1472108337.943:10): apparmor="STATUS" operation="profile_load" name="/usr/sbin/ippusbxd" pid=2557 comm="apparmor_parser"
[  103.699594] type=1400 audit(1472108337.963:11): apparmor="STATUS" operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" pid=2556 comm="apparmor_parser"
[  104.327027] libphy: 1c30000.eth: probed
[  104.327179] sunxi-gmac 1c30000.eth eth0: eth0: PHY ID 001cc915 at 0 IRQ poll (1c30000.eth-0:00)
[  110.230457] libphy: 1c30000.eth-0:00 - Link is Up - 1000/Full
No news on that? Is the problem still there, @RaimundEge ?
  Kickstarter P64 with LCD, working image? MostHated 1 7,915 01-04-2020, 10:32 AM
Last Post: igorp
  Ubuntu password not working joemassimino 4 14,228 05-18-2018, 03:33 PM
Last Post: Luke
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 6,805 04-16-2018, 03:09 PM
Last Post: Rocklobster
  Software Boutique- not working Partymack711 4 9,832 02-17-2018, 03:25 PM
Last Post: Partymack711
  Bluetooth not working reesh95 11 24,073 06-26-2017, 09:56 PM
Last Post: pfeerick
Photo Ubuntu not working for me Macs1337 8 18,161 09-18-2016, 11:08 PM
Last Post: tkaiser
  Ethernet not working on Xubuntu 20160528 build a_fad 2 7,141 06-26-2016, 01:19 AM
Last Post: dkryder
