LCD Panel Connected but does not work
Hi I have recently received my package containing the pine a64 mother board, with lcd display, package is missing the shutdown button, and also the abs case at the Moment.Anyway I received also the 7" LCD Display, I have connected the cables as it was documented in this Forum guide. I did not do any OS upgrade yet, but when I start the os boot up, Display does not light up. I tried to move the ribbon cables attached on the dsi port, and if moved, starts flashing like it was going to start, but then nothing.
I think that the Motherboard or the ribbon cable is defected. Any suggestions?
Make sure the cables are set, and do not 'move' them... leave them alone.
The only image that works with the LCD please, is the LCD Android image; try that.
  7 inch LCD touch panel is upside down? joshpl 2 5,226 12-07-2023, 06:18 AM
Last Post: stormwyrm
  What other devices can the LCD screen work on? kodachrome 1 5,446 12-07-2019, 06:50 PM
Last Post: kodachrome
  LCD panel Driver IC MIPIguy 1 5,590 08-12-2017, 05:04 PM
  I2C Touch Panel mbt28 0 3,575 06-12-2017, 11:32 AM
Last Post: mbt28
  LCD touch panel emits low power Naccies 4 10,659 01-09-2017, 07:45 PM
  Lcd panel's pixels are not square bokeer 0 3,157 11-22-2016, 08:08 PM
Last Post: bokeer
  LCD Panel not working at all treize 7 16,738 09-19-2016, 10:24 PM
Last Post: billjon
Photo Running Out Of Options LCD Panel Just Not Working AUDIOTEK 4 8,962 07-27-2016, 06:34 PM
Last Post: AUDIOTEK
  how to make 7 inch lcd work chong 16 37,879 05-29-2016, 05:35 PM
Last Post: UnixOutlaw
Bug Raspberry Pi 7" Touchscreen Display not work? Paara 2 8,701 05-05-2016, 08:47 AM
