New to the Pine64 : Distro recommendation
I am new to the world of one board computer and the Pine64 is my first experience.
I have purchase a 1GB and a 2GB model with one Wifi board.
I have put small heatsinks on both processor
Using the linux dd command, I successfully burned a RemixOs on a 16GB  class 10 micro-SD card and I am able to boot busing my HDMI TV
But they are is very slow.  Much slower than expected.
I am looking for a suggestion for another distribution that would be faster (more responsive) than RemixOs.
hi, the answer to your question depends what you mean by very slow.
... if you mean video latency (video fps response, as a media or gaming center) this is a known problem which is being addressed now; its not quite there yet.
Let me answer your question this way; I am using my PineA64 as my normal standard desk PC now for more than 10 weeks--- most of this summer (debian mate). It is VERY responsive and handles my day to day tasks very well--- honestly.
On the other hand, folks trying to use the PineA64 board as a media center appliance are having some issues; mostly related to the video. Also, some are having ethernet issues (speeds of 1 GbE) which is also being addressed now, but which so far do not have solid solutions (it will get there, just not there yet).
So, the question is, what do you want to use your PineA64 for; why did you purchase it, and what were your expectations?
(08-14-2016, 01:17 PM)MarkHaysHarris777 Wrote: hi, the answer to your question depends what you mean by very slow.
The Remix OS looks great however, there is a 5-10 second delay when I click on an icon.  Once in an application, it seems to run fine.
So far I have only tried benchmark programs  (Antutu, 3dMark and PCMArk).  I knew that the Pine64 would not be as fast as my smartphone, but the 5-10 sec lag is annoying and I simply want to setup another sd-card with the fastest distribution possible
I have two project but my first goal is to tinker with these
Project #1  I would like to benchmark my Pine64 against two old laptop that I have
Project #2  I want to build a Kodi box to replace an old Optiplex Dell computer that Iis running Kodi right now
Project #3  I want to setup a headless board running a proxy running "No Track"  http://quidsup.net/notrack/
Test the SD card for 4kb iops performance. I recommend the Samsung EVO SD cards.
Sent from my HTC 10 using Tapatalk
(08-15-2016, 06:42 PM)benpope81 Wrote: Test the SD card for 4kb iops performance. I recommend the Samsung EVO SD cards.
I just wonder Samsung EVO 4kb speed is how fast ,how about vs class 10 sandisk card.
(08-15-2016, 09:31 PM)listenfree Wrote: I just wonder Samsung EVO 4kb speed is how fast ,how about vs class 10 sandisk card.
http://forum.pine64.org/showthread.php?t...ne#pid9042
Sandisk make more than one class 10 card, so I have no idea, but in my experience, the Samsung is noticably faster than the Sandisk cards I've tried, which is why I recommend it.
The class is about the minimum sequential ransfer rate, which is pretty much irrelevant, since that's not a typical usage pattern for an OS, and you'll saturate at about 23MB/s on the Pine64 anyway.
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 10,622 10-21-2025, 10:13 AM
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,842 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 7,266 06-17-2021, 05:35 AM
Last Post: kqlnut
  Just discovered Pine64 ! - first Q philip_rhoades 4 10,469 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 6,722 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 218,044 01-15-2020, 12:46 PM
  Emails from pine64 received as spam by gmail Matan 2 15,540 08-21-2019, 08:30 AM
Last Post: Leiaz
  How to handle a Pine64 correctly gbjensen 6 23,407 03-28-2019, 11:43 PM
Last Post: InsideJob
Information Creating a NAS server in Pine64 javi_cala 4 12,700 01-21-2019, 02:03 AM
Last Post: bartes
  The 6 most common reasons why Pine64 won't boot Andrew2 109 311,342 10-11-2018, 11:35 PM
Last Post: Technolab88
