Windows 10 IoT finally released on Pine A64 platform
The Pine A64 already passed the Windows 10 Azure IoT certification: https://azure.microsoft.com/en-us/docume...gurations/
For the Pine A64 Windoiws IoT installation process, please refer to https://github.com/Azure/azure-iot-sdks/...-csharp.md
For the Pine A64 Window IoT code, please download from Pine64 file server: http://files.pine64.org/os/win10-iot/Win...Pine64.ffu
For developer that interest on the Pine A64 Windows IoT SDK, please stays tune. We will release the UEFI source code and Win10 BSP SDK package in few weeks time Smile
Seems like some users encounter " Failed to write provisioning file to the microSD Card" when programmign teh microSD card, this issue has been reported and investigated.
That is good news for people that want to experiment with 10 IoT Core , is there any documentation around what hardware and interfaces are supported by this port, what about thermal/power management?
(08-05-2016, 04:52 AM)xalius Wrote: That is good news for people that want to experiment with 10 IoT Core , is there any documentation around what hardware and interfaces are supported by this port, what about thermal/power management?
At current time, still bare.
There is a new image release for Pine64's Wins 10 IoT
For release note and installation procedure, here is the github link: https://github.com/Leeway213/Win10-IoT-f...seNotes.md
For the new 20160809ffu build release, please download from this link: http://files.pine64.org/os/win10-iot/Pin...eta0.1.ffu
i do not see image file?
(08-09-2016, 04:29 AM)dkryder Wrote: i do not see image file?
Sorry, here is the link: http://files.pine64.org/os/win10-iot/Pin...eta0.1.ffu
Any updates on the SDK and the UEFI source code?
Donate BTC: 3Eav9uqXi8Nx1axb7QjK6xV4km4K9YGv9a
has anyone tried to put a bios onto the sd card so any os can be use from the usb port using a memory stick or a hard drive
As you can already see, several operating systems are already available for the PineA64; gnu+linux (several flavors, including now Gentoo), Remix, Android, and others. Bios of course does not make sense for the PineA64; however, some are experimenting with UEFI.
gnu+linux supports virtualization; in fact, that is why Simon Eissenmann (longsleep) built the linux kernel for the pine board in the first place. Containers , Docker , work on the pine board , and any number of things might run in a VM.
It is possible to boot to an sdd, hdd, but you must use the SD card to get there. The rootfs then installs on the disk; the SD card points to the disk (I am over-simlifying here).
hope you enjoy your pine board, best of luck to you
  Windows 10 IoT Enterprise? roybridge 1 20,834 03-06-2019, 02:42 PM
  Windows IoT BSP dvescovi 16 43,457 09-02-2018, 06:35 PM
Sad Windows 10 iot ffu lawrencejd 1 8,316 07-19-2018, 10:40 PM
Last Post: KNERD
  Win10 IoT (PINE A64(+)) 10.0.15063.0_20170602 pineadmin 30 77,009 05-18-2018, 07:05 AM
Last Post: dkryder
  +LTS/SOPINE Can Win10 IOT be used on PINE A64-LTS? uart 1 7,622 03-09-2018, 11:25 PM
  unable to deploy my application to the Pine using Visual Studio 2017 Matthew 9 22,549 03-08-2018, 04:20 AM
Last Post: zio69
  Will Windows 10 work with the new Rock board? WhiskerBiscuit 2 10,034 09-03-2017, 07:22 PM
  Windows 10 and .Net Core running for a day hugob 2 10,714 08-23-2017, 11:17 AM
Last Post: hugob
Star Windows IoT BSP on Github!!!! Add UEFI src code! Leeway213 5 18,101 06-25-2017, 07:42 PM
Last Post: Leeway213
  Pine 64 on 512MB embedder 3 12,453 12-19-2016, 07:56 PM
Last Post: Toriless
