camera module and lcd integration
is the camera module supposed to fit into the slot in the lcd panel? it's a bit big, and does not fit. see picture.
https://imgur.com/uiJQq5s
[Image: uiJQq5s.jpg]
This may take some creative 'maker' DIY ingenuinty.
I don't have mine yet, so I have not played around with it... but I know that there is only one camera module supported at this moment. The Raspberry PI camera WILL NOT work. The opening may need to be altered with a dremel/ can't say anything too specific atm.
marcus
(07-13-2016, 07:22 PM)jodybrown99 Wrote: is the camera module supposed to fit into the slot in the lcd panel? it's a bit big, and does not fit. see picture.
Yeah, same here.  Absolutely crazy.  Wait till you try to mount the LCD in the playbox enclosure.  The cables aren't long enough.
The sensor is 8.5 mm and the hole is 6.7...... Smile Only thing you can do is cut the walls and glue it in.
Yeah, sadly, tllim says the enclosure was designed for the smaller camera, not the 5mp camera.
Absolutely genius. :-(
Came here expecting to be disappointed, everything worked out as anticipated. XD
Marks's dremel idea is probably the best option. Now, to make it work without damaging anything...
  Anyone get the camera to work yet? Havensal 16 41,208 09-13-2022, 03:31 AM
Last Post: harryaxe31
  camera port details? gourmand007 6 21,774 03-07-2021, 05:29 PM
Last Post: DippingMyToesIn
  About the camera robopo 11 31,740 03-06-2021, 12:28 AM
  CSI / Camera Module Compatibility? vade 8 25,624 04-03-2020, 05:39 AM
Last Post: Ellesar Dragon
  13MP Camera cable extension saviod 2 8,876 06-21-2019, 06:05 AM
Last Post: saviod
  Camera Sasank 15 40,136 12-13-2018, 09:08 PM
Last Post: Mutani
  Himax 5 Megapixel Camera Module cannot fit into 7″ LCD Touch Screen Panel themyshop 3 11,510 05-10-2018, 04:28 PM
  Webcam vs camera module on pine64+ fkpkot 4 15,384 02-27-2017, 03:57 PM
Last Post: MarkHaysHarris777
  Camera is working on Linux @lex 50 138,408 10-26-2016, 03:17 PM
Last Post: @lex
