Using 4GB microSD
I have a class 10 4GB microSD card that I would like to use with pine 64 1GB RAM. However, on the downloads section I can only find ROMs for 8/16/32 GB cards. Can I create a 4GB ROM by myself? How?
hi, first make the image you are interested in, and then, mount it as a loopback device. You then can copy the contents of the mounted image file over to the 4Gb card that you're interested in.
The 4G card needs at least two partitions, 1 for /boot, and the other for the / rootfs.
I will post the directions for mounting a loopback device on here a little later...
marcus
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 6,539 12-10-2024, 07:23 PM
Last Post: Dendrocalamus64
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 212,761 01-15-2020, 12:46 PM
  corrupt microsd card after reboot maxpayne 6 15,839 02-08-2017, 05:42 PM
Last Post: maxpayne
  Great microSD on discount! SkimMilk 3 7,397 07-20-2016, 10:11 PM
Last Post: SkimMilk
  OS Suitable for 2GB MicroSD? MonarchOfLight 2 5,475 05-04-2016, 11:17 PM
Last Post: longsleep
  Partitioning MicroSD card for boot/storage KillrKowalski 6 12,412 05-04-2016, 07:13 AM
Last Post: Leoncito81
Question creating bootable remixOS/android MicroSD on Mac OS X or linux? faddah 3 18,001 04-18-2016, 09:46 AM
