Ubuntu Error updating uboot
I booted ubuntu on my Pine 64+ 2GB per this guide. I used the Ubuntu Base Longsleep download.  It booted just fine, but when i try to run the command to update uboot, i get this error.  The pine is connected to the network via cat-6 cable.  I can ping google.com and i can SSH to the pine from my desktop, so I know it's got a good network connection.
ubuntu@localhost:~$ sudo -i [sudo] password for ubuntu: root@localhost:~# /usr/local/sbin/pine64_update_uboot.sh Checking for update ... Downloading U-Boot image ... curl: (56) GnuTLS recv error (-54): Error in the pull function. root@localhost:~# /usr/local/sbin/pine64_update_kernel.sh Checking for update ... Downloading Linux Kernel ... curl: (56) GnuTLS recv error (-54): Error in the pull function. root@localhost:~#
Any ideas?
(07-14-2016, 10:35 AM)jandvs Wrote: I booted ubuntu on my Pine 64+ 2GB per this guide. I used the Ubuntu Base Longsleep download.  It booted just fine, but when i try to run the command to update uboot, i get this error.  The pine is connected to the network via cat-6 cable.  I can ping google.com and i can SSH to the pine from my desktop, so I know it's got a good network connection.
Any ideas?
curl error 56 means it can't connect
http://curl.haxx.se/libcurl/c/libcurl-errors.html
try doing a curl of google.com and see if that works. ping can potentially work, but when you go to connect to a website, that can fail due to other network reasons (usually firewalls)
curl -v -k --head https://www.google.com/
(if you dont have curl, sudo apt-get install curl)
Your TLS connectivity is broken. It can be as simple as wrong system time up to a full man-in-the-middle decrypting proxy. Check your setup.
  Issues with both Deb and Ubuntu germanshep 0 4,460 08-28-2018, 05:47 PM
Last Post: germanshep
  Help debug my pine64A+ ubuntu/plex hangs XaRz 8 17,093 11-02-2017, 06:34 AM
Last Post: XaRz
  Ubuntu 16.04 cannot resolve dns - connection timed out; no servers could be reached marcosti 2 13,165 03-01-2017, 02:46 PM
Last Post: dkryder
Question Need help : Issue in running compiled kernel with tftp+uboot dinesh.bhoyar 2 8,114 01-30-2017, 12:44 AM
Last Post: dinesh.bhoyar
Question Ultrawide Display for Ubuntu Mate DE dudeytsang 1 7,656 01-01-2017, 07:26 AM
Last Post: CaptainZalo
  Pine64+Ubuntu+Tvheadend+DVBT Dongle Shai 3 10,730 10-03-2016, 04:23 AM
Last Post: Shai
  Dmesg output Ubuntu Mate S265 1 5,930 10-02-2016, 07:28 AM
Last Post: MarkHaysHarris777
  Overclocking ubuntu mate Mixermic 2 8,071 10-01-2016, 04:36 AM
Last Post: pfeerick
  How to make multicast working on ubuntu and debian brengthdom 3 10,682 09-18-2016, 02:05 PM
Last Post: brengthdom
  Camera support - Ubuntu Xenial 16.04 LTS @lex 3 9,003 08-07-2016, 03:47 AM
Last Post: romansavrulin
