alsactl triggers kernel warning
I just noticed that alsactl triggers a kernel warning whenever I try to use it with the sunxi audiocodec modules loaded:
[  264.405729] ------------[ cut here ]------------
[  264.410878] WARNING: at drivers/clk/clk.c:781 __clk_disable+0x40/0x78()
[  264.418191] Modules linked in: sunxi_i2s sunxi_codec sunxi_sndcodec bnep hci_uart bluetooth vfe_v4l2 videobuf2_dma_contig videobuf2_memops mali(O) ir_lirc_codec lirc_dev ir_sony_decoder ir_sanyo_decoder ir_jvc_decoder ir_rc6_decoder videobuf2_core ir_rc5_decoder vfe_io ir_nec_decoder ir_mce_kbd_decoder ss sunxi_ir_rx cedar_ve 8723bs cfg80211
[  264.451824] CPU: 3 PID: 1821 Comm: alsactl Tainted: G           O 3.10.102-0-pine64-longsleep #7
[  264.461540] Call trace:
[  264.464254] [<ffffffc000088388>] dump_backtrace+0x0/0x118
[  264.470229] [<ffffffc0000884c4>] show_stack+0x24/0x30
[  264.475824] [<ffffffc00070e6a0>] dump_stack+0x20/0x28
[  264.481416] [<ffffffc0000addb8>] warn_slowpath_common+0x80/0xa8
[  264.487967] [<ffffffc0000adf1c>] warn_slowpath_null+0x3c/0x4c
[  264.494325] [<ffffffc0005a3fa4>] __clk_disable+0x40/0x78
[  264.500202] [<ffffffc0005a4004>] clk_disable+0x28/0x3c
[  264.505896] [<ffffffbffc5147e4>] set_src_function+0x100/0x190 [sunxi_codec]
[  264.513604] [<ffffffc0005b62d8>] snd_ctl_elem_write+0xd4/0x148
[  264.520060] [<ffffffc0005b7dc0>] snd_ctl_ioctl+0x3b4/0x708
[  264.526132] [<ffffffc0001c0074>] vfs_ioctl+0x4c/0x6c
[  264.531625] [<ffffffc0001c09fc>] do_vfs_ioctl+0x4a4/0x538
[  264.537597] [<ffffffc0001c0af8>] SyS_ioctl+0x68/0x98
[  264.543086] ---[ end trace 072b838cd4b4f7fb ]---
[  264.548340] ------------[ cut here ]------------
[  264.554787] WARNING: at drivers/clk/clk.c:690 __clk_unprepare+0x34/0x84()
[  264.562369] Modules linked in: sunxi_i2s sunxi_codec sunxi_sndcodec bnep hci_uart bluetooth vfe_v4l2 videobuf2_dma_contig videobuf2_memops mali(O) ir_lirc_codec lirc_dev ir_sony_decoder ir_sanyo_decoder ir_jvc_decoder ir_rc6_decoder videobuf2_core ir_rc5_decoder vfe_io ir_nec_decoder ir_mce_kbd_decoder ss sunxi_ir_rx cedar_ve 8723bs cfg80211
[  264.596282] CPU: 3 PID: 1821 Comm: alsactl Tainted: G        W  O 3.10.102-0-pine64-longsleep #7
[  264.606027] Call trace:
[  264.609584] [<ffffffc000088388>] dump_backtrace+0x0/0x118
[  264.615564] [<ffffffc0000884c4>] show_stack+0x24/0x30
[  264.621206] [<ffffffc00070e6a0>] dump_stack+0x20/0x28
[  264.627014] [<ffffffc0000addb8>] warn_slowpath_common+0x80/0xa8
[  264.633613] [<ffffffc0000adf1c>] warn_slowpath_null+0x3c/0x4c
[  264.640173] [<ffffffc0005a4a5c>] __clk_unprepare+0x34/0x84
[  264.646245] [<ffffffc0005a4ad0>] clk_unprepare+0x24/0x34
[  264.652171] [<ffffffbffc5147ec>] set_src_function+0x108/0x190 [sunxi_codec]
[  264.660088] [<ffffffc0005b62d8>] snd_ctl_elem_write+0xd4/0x148
[  264.666546] [<ffffffc0005b7dc0>] snd_ctl_ioctl+0x3b4/0x708
[  264.672664] [<ffffffc0001c0074>] vfs_ioctl+0x4c/0x6c
[  264.678366] [<ffffffc0001c09fc>] do_vfs_ioctl+0x4a4/0x538
[  264.684343] [<ffffffc0001c0af8>] SyS_ioctl+0x68/0x98
[  264.689874] ---[ end trace 072b838cd4b4f7fc ]---
debian@pine64:~$ lsmod
Module                  Size  Used by
sunxi_i2s              13081  2
sunxi_codec            63040  1
sunxi_sndcodec         17150  1
bnep                   17511  2
hci_uart               27742  1
bluetooth             195943  21 bnep,hci_uart
vfe_v4l2              747618  0
videobuf2_dma_contig    17668  1 vfe_v4l2
videobuf2_memops       12546  1 videobuf2_dma_contig
mali                  199851  0
ir_lirc_codec          12756  0
lirc_dev               17032  1 ir_lirc_codec
ir_sony_decoder        12489  0
ir_sanyo_decoder       12491  0
ir_jvc_decoder         12487  0
ir_rc6_decoder         12520  0
videobuf2_core         30952  1 vfe_v4l2
ir_rc5_decoder         12487  0
vfe_io                 34085  1 vfe_v4l2
ir_nec_decoder         12487  0
ir_mce_kbd_decoder     12628  0
ss                     33083  0
sunxi_ir_rx            12902  0
cedar_ve               17368  0
8723bs               1365012  0
cfg80211              374207  1 8723bs
Is that something that can be safely ignored? Trying to look at the referenced code in /drivers/clk/clk.c now....
That same message appears in my dmesg several times during bootup. I've been ignoring it because my sound works just fine, except that whenever sound starts playing, my screen blanks out for 3-4 seconds and then comes back. I suspect that is somehow related to my HDMI>VGA adapter though.
I looked into /drivers/clk/clk.c ....
Apparently clk_disable() gets called with no cloks enabled:
781: if (WARN_ON(clk->enable_count==0)) return;
and subsequently clk_unprepare() returns similar to that:
690: if (WARN_ON(clk->prepare_count ==0) return;
so basically clk_disable() gets called for some reason and there is no clock to disable, so this is maybe just a glitch or is something broken?
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,291 11-13-2019, 09:41 AM
Last Post: roel
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,841 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 4,300 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 121,198 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,218 06-21-2018, 05:45 PM
Last Post: evilbunny
  Kernel for A64 git longsleep 179 428,648 03-25-2018, 03:25 PM
Last Post: Luke
  Gentoo for pine64 - longsleep kernel incoherent 0 5,580 12-09-2017, 08:14 AM
Last Post: incoherent
  [SOLVED] UEFI + Fedora Mainline Kernel Booting! cztian 0 5,084 07-13-2017, 08:38 PM
Last Post: cztian
  Mainline kernel [Solved] jeroen79 11 29,487 02-08-2017, 06:19 AM
Last Post: umiddelb
Question Need help : Issue in running compiled kernel with tftp+uboot dinesh.bhoyar 2 7,866 01-30-2017, 12:44 AM
Last Post: dinesh.bhoyar
