Battery boost circuit
I assume there is a voltage boost circuit to power the board from the Lithium battery, and I would like to know what is the current limit for the boost circuit?
(01-29-2016, 01:45 PM)stephen fleming Wrote: I assume there is a voltage boost circuit to power the board from the Lithium battery, and I would like to know what is the current limit for the boost circuit?
Maximum charging current is 2800mA. For more info, please refer to AXP803 datasheet: https://drive.google.com/file/d/0B0cEs0l...JCR2s/view
What I want to know is how much power could be supplied by the battery. The reason is that I am considering connecting up a small stereo amp like this and a couple of small speakers:
https://www.adafruit.com/products/1712
I plan on using the 8000mAh accessory battery.
I changed my mind and decided to use one of the hifi boards that I here are being designed for the Pine 64.
So I browsed through the datasheet for the chip and it looks like everything is configured by data registers.
Will there be a software option to configure these specific to the battery we want to use? (ie. 1A+ charge current for high capacity batteries)
Obviously the chip supports up to 2.8A charging, but thermal management becomes an issue.  What is the functional limit due to lack of active cooling?
(02-04-2016, 06:55 AM)adk_mechetech Wrote: So I browsed through the datasheet for the chip and it looks like everything is configured by data registers.
Current there is no software option to do so due to reliability concern. Just like you have mentioned, if somebody just crank up the charging current without knowing the consequence, it can become a disaster.
What is the charge current set to by default? Will there be any way at all to access the control registers or modify firmware to change it? (not an app that any user could install and mess with).
The PMU datasheet AXP803 already published in Pine64 wiki site, yoy also welcome to check out. I don't have the default charge current info handy and will publish when received.
Rainbow Lithium battery temperature readout? GregH 0 3,238 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 107,764 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 6,741 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 9,091 02-17-2017, 08:18 PM
  CR2032 Battery holder - sanity check xalius 23 46,995 01-23-2017, 07:41 PM
Last Post: DonFL
  Battery temp pin? SvdSinner 1 6,208 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 87,493 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 15,656 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 3,849 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 3,758 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
