PineA64 Getting Started Guide
(07-07-2016, 01:48 AM)grantos Wrote:
(07-06-2016, 11:53 PM)Ghost Wrote: @grantos: which operating system are you using? Are you using LCD Touchscreen or HDMI TV/Monitor?
You could try another operating system (or another earlier/later version of the same OS) to see if the issue is software-related.
Cheers @Ghost.
that was one of my next solutions, also pine accidentally sent two wifi modules so will try that also.
Do you have pic of how you attached yours
Currently using remixes on 2gb board
Using HDMI on a TV fixed image by turning over scan off
A pic of mine would look pretty much the same as your pic, except my antenna cable is stuck to the top of the acrylic case.
My only thought would be that the antenna cable isn't pushed in properly all the way.
Lenny has some really nice looking starting guides up on his site now:
linux
android
remix os
(07-02-2016, 07:52 PM)grantos Wrote: All the startup guides seems to be software related, have only seen one video on install your pine in the acrylic case. Nothing on how to install modules like wifi/Bluetooth or zwave.
nothing on where to use the power button
Hi Grantos,
I know! I have the exact cluelessness on how to even tell if it's working or not. I'm struggling bad with Pine64.
Wink Where should I post a PineBuds Pro repair and battery replacement guide? waitingpio 3 1,553 08-08-2026, 06:56 PM
  Guide: Setup Latest Waydroid for Hardware Acceleration and/or Development nroth 2 16,092 11-11-2022, 04:47 PM
Last Post: nroth
  Getting started in nRF52 in pinetime64 Quim 0 3,768 06-14-2020, 02:02 PM
Last Post: Quim
  Any success working with OpenCV on the PineA64? Tonny91 0 3,904 10-16-2018, 09:16 PM
Last Post: Tonny91
  How to get started? riahim 35 98,687 10-19-2017, 02:04 PM
Last Post: hikmetsezen
  PineA64 512 reboot - board shut down indrajith 7 19,239 07-28-2016, 02:07 PM
Last Post: Ghost
  Startup Guide (READ THIS FIRST) ScorpionTNT 3 10,200 07-18-2016, 10:33 AM
Last Post: Luke
  Getting started using OSX cranchh 17 46,465 06-23-2016, 11:40 AM
Last Post: killorfb
  Youtube video on PineA64 Development Board khgoh 0 7,020 03-30-2016, 11:25 PM
Last Post: khgoh
