General Battery Questions
(06-22-2016, 09:11 AM)xalius Wrote:
(06-22-2016, 06:10 AM)nspireing Wrote:
(06-21-2016, 09:32 PM)martinayotte Wrote: Not exactly, they should be right angle like those one : http://www.ebay.ca/itm/20pcs-Tact-Switch...0711178897
did I see on the board it has a spot for a power and reset button?
Yes, the board has a power button which connects to the PMIC (Power-Management IC) and also can triggers certain events in an operating system. The second button is a Reset button. There are also to spots where you can solder two LEDs. One is a charger indication LED and the other is connected to a Pin on the A64 and you can control that from your software. The PMIC has an integrated, programmable battery charger that usually charges the battery if DC input voltage is available and no undervoltage/overvoltage/overcurrent/overtemperature faults are detected... once the OS has booted, the charger is also controlled by various pieces of software, like on a tablet or cellphone... see here for the LEDs: http://forum.pine64.org/showthread.php?t...6#pid13006
Can you point me to some documentation for these OS events? Thanks!
(07-02-2016, 08:26 AM)johnr Wrote: Can you point me to some documentation for these OS events? Thanks!
This thread should get you started! Big Grin It's all a bit trial and error at the moment!
  Questions. board serial.? bongky youn 8 17,720 09-12-2016, 09:24 AM
Last Post: bongky youn
  Lithium Polymer Battery USA / CERTAIN EUROPE COUNTRIES ONLY JulianM 11 26,834 09-07-2016, 04:40 PM
Last Post: Mednar
  Compatible Battery Types/Brands List AUDIOTEK 23 49,795 07-20-2016, 06:10 PM
Last Post: Bluphire
Question lipo battery boot issue Luke 5 12,988 05-29-2016, 02:13 PM
Last Post: Luke
  RTC battery steve8939 2 7,522 05-25-2016, 04:58 PM
Last Post: steve8939
Question Camera / Lcd / Battery documentation soufyen 1 5,806 04-29-2016, 03:24 PM
Lightbulb What is the third battery pin for? combs 1 6,249 04-20-2016, 04:39 PM
Last Post: rahlquist
  Few Hardware Questions dav3yb 3 10,075 03-20-2016, 11:06 AM
  battery hazerty 11 26,029 03-14-2016, 08:46 AM
  Shipping battery to Europe makimoki 2 7,626 02-22-2016, 12:21 AM
Last Post: Ghost
