Greenish Screen
I just loaded Android 5.1.1 Image Release 20160505 to my PINE64 and the monitor seems to have a greenish tinge to it. Is that normal? Has anyone else experienced this?
Thank you.
Are you using an HDMI -> DVI converter ?
If you are then colour distortion is a know "issue" (or effect), if you are not using a converter then no, its not normal
Ah ha... Yes my monitor is DVI and I'm using a HDMI-to-DVI cable. Sorry for not realizing this was a known issue.
  screen rotating Miguelito71 0 5,109 07-29-2019, 12:48 AM
Last Post: Miguelito71
  Youtube TV experience/ screen resolution issues gubaguba 0 3,434 02-22-2018, 09:12 AM
Last Post: gubaguba
  Android 6.0 How to turn the screen back on modsbyus 4 9,200 11-28-2017, 01:03 PM
Last Post: modsbyus
  Orange Screen All versions of Android TV XsoundXhoundX 17 35,763 05-19-2017, 01:27 AM
Last Post: Israeldelamo
  Screen wakeup Danja 17 35,596 12-22-2016, 05:30 AM
Last Post: Workaholic
  Touch not working with Android and touch screen erichardson30 5 15,264 09-13-2016, 11:12 AM
Last Post: MarkHaysHarris777
  Can I rotate Screen Android 5.1.1 for LCD (not rooted) steveslim 4 12,070 09-04-2016, 09:35 PM
Last Post: steveslim
  What happened to the images for the7" touch screen? tanarri 1 5,967 08-29-2016, 11:37 AM
Last Post: Ghost
  Disable lock screen on Android 5.1 Blindstealer 0 3,133 07-27-2016, 04:26 AM
Last Post: Blindstealer
  AB Login screen when booting Android Ghost 0 3,499 06-16-2016, 10:16 AM
Last Post: Ghost
