Anyone get the camera to work yet?
(06-20-2016, 06:33 PM)@lex Wrote: I just got my Pine64+ with the camera module and it works with Android and HDMI (Full HD). I will provide some info to longsleep so he can work on the linux side.
Care to share how you got it working on Android? Mine doesn't find it.
Sent from my iPhone using Tapatalk
Something to note: the camera module has been re-designed, it looks different (the FPC cable) from the pictures. My board was delayed due to the camera module, i was not lucky at first but this happen for the good.
Here is how it is connected, so you can check if you have same FPC cable design: https://drive.google.com/open?id=0B7A7OP...UlxdDZMTXM
And this sensor is s5k4ec not hm5065, no AF.
Mine looks just like that.
Ok, Please, we need more info:
* Which Android version and the Link you used to download?
* Your board revision (is printed on the board)?
* Can you get some logs using the debugging port?
* Double check if you inserted the FPC cable exactly as the picture, push until the end of the connector carefully.
How can I use the CSI camera on Ubuntu when starting from http://forum.pine64.org/showthread.php?tid=1481 ?
I've recently used this camera to take some images of myself. I, therefore, had good results. My favorite pic is with Quackity thick hoodie https://quackitymerchandise.shop/product...ty-hoodies.
  camera port details? gourmand007 6 21,778 03-07-2021, 05:29 PM
Last Post: DippingMyToesIn
  About the camera robopo 11 31,742 03-06-2021, 12:28 AM
  CSI / Camera Module Compatibility? vade 8 25,627 04-03-2020, 05:39 AM
Last Post: Ellesar Dragon
  13MP Camera cable extension saviod 2 8,880 06-21-2019, 06:05 AM
Last Post: saviod
  Camera Sasank 15 40,142 12-13-2018, 09:08 PM
Last Post: Mutani
  Himax 5 Megapixel Camera Module cannot fit into 7″ LCD Touch Screen Panel themyshop 3 11,517 05-10-2018, 04:28 PM
  Webcam vs camera module on pine64+ fkpkot 4 15,387 02-27-2017, 03:57 PM
Last Post: MarkHaysHarris777
  Camera is working on Linux @lex 50 138,503 10-26-2016, 03:17 PM
Last Post: @lex
  camera module and lcd integration jodybrown99 5 15,283 10-11-2016, 11:35 AM
Last Post: hikaricore
