(ARCHIVED) Ubuntu Xenial Image (BSP Kernel)
I'm using a USB flash drive.
I'm using cp to copy /var/cache/apt/archives (848MB) back and forth - no errors and same size.
Hey there,
When is the next kernel update planned for release? I'm having success getting things running on my boards and am anxious to make use of the iSCSI module.
Thanks!
-Justin
Building new Kernel now.
Hi longsleep and thanks for all the effort. Can you include the IR driver (sunxi-ir-rx) as a module in your config? I just built it myself with your sources and tested it:
http://forum.pine64.org/showthread.php?tid=1424
Wink
(06-08-2016, 08:34 AM)coolnine98 Wrote:
(06-08-2016, 05:04 AM)longsleep Wrote: Well most certainly you suffer from undervoltage and your Drive just shuts down.
I have installed the image and working great. Thanks longsleep. I have managed to solve HDMI and Headphone voice.
I have set up auto login but still it ask me to click on my id (no password) on boot. How do I get rid of that and simply just boot into the desktop?
I'll assume that your Pine board is safely at home under close supervision. [Image: cool.png]   Also, I'll assume that you are using a LightDM-based distro like Ubuntu MATE or Xubuntu.  If you'd like to automatically login as YOUR-USER-NAME, then do the following:
sudo YOUR-FAVORITE-EDITOR /etc/lightdm/lightdm.conf
and add something like the following lines, save, and exit (you might be actually creating the file):
[SeatDefaults]
allow-guest=false
autologin-guest=false
autologin-user=YOUR-USER-NAME
autologin-user-timeout=0
autologin-session=lightdm-autologin
A full installation process that I used based on Longsleep's work (if you have any interest) appears here: https://www.element14.com/community/comm...4-with-2gb
The next time you power up or reboot, you should go immediately into the desktop associated with YOUR-USER-NAME.
(06-17-2016, 12:14 PM)xalius Wrote: Hi longsleep and thanks for all the effort. Can you include the IR driver (sunxi-ir-rx) as a module in your config? I just built it myself with your sources and tested it:
Done - see https://github.com/longsleep/linux-pine6...b7d2848162
(06-17-2016, 12:07 PM)longsleep Wrote: Building new Kernel now.
Looks great; thanks!
(02-28-2016, 03:07 PM)longsleep Wrote: I also built a mimimal Ubuntu image combined with the the BSP Kernel and my image building gear. Similar to the Arch Image **this image is intended for developers. If you are looking for accelerated 2D/3D or video decoding use Android** and do not bother with trying this image.
Let me know what you think.
Longsleep,
  Noob nere. I keep seeing "image." Ubuntu image, download image, etc, etc image.
I thought images were pictures.
What exactly does it mean to say; "Ubuntu image"?
Thank you.
Rickyroller5
Longsleep,
Thank you.
Rickyroller5
He means a disk volume image.  A disk volume image generally takes the form of a file which is input to the Unix/Linux `dd` utility in creating the actual disk volume.
@longsleep, thanks for all you do... very nice work.
  Ubuntu server 20.04 request phi0x 2 11,148 12-30-2020, 08:02 PM
Last Post: phi0x
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,613 08-30-2020, 10:35 AM
Last Post: jrronimo
  Kickstarter P64 with LCD, working image? MostHated 1 8,008 01-04-2020, 10:32 AM
Last Post: igorp
  USB Wireless Drivers with Longsleep Linux Kernel jacobscarter 15 41,612 03-06-2019, 02:26 PM
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 8,550 02-01-2019, 05:09 AM
  SPI on ubuntu IlyaM 4 14,776 07-16-2018, 03:00 AM
Last Post: kingflab
  Ubuntu password not working joemassimino 4 14,381 05-18-2018, 03:33 PM
Last Post: Luke
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 6,872 04-16-2018, 03:09 PM
Last Post: Rocklobster
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,721 02-01-2018, 09:45 AM
Last Post: Partymack711
  PPTP doesnt work with ubuntu escovedo 2 13,628 08-23-2017, 09:28 AM
Last Post: gilbertotcc
Users browsing this thread: 7 Guest(s)
