Has anyone tried FygoOS on a PINE64 ROCKPro64?
Wink
I’m considering turning a ROCKPro64 into a small two-drive NAS using the PINE64 NAS case and a PCIe-to-SATA adapter.
FygoOS supports ARM and Rockchip hardware, and its ARM documentation includes an RK3399 loader. Since the ROCKPro64 also uses the RK3399, the combination looks possible, but I have not found a clear report confirming that FygoOS boots and works properly on this exact board.
Has anyone here tried it?
I’m particularly interested in whether FygoOS can boot from eMMC or an attached drive on the ROCKPro64, and whether the PCIe SATA adapter is detected without additional kernel or device-tree changes. I’d also like to know whether drive monitoring, RAID, hibernation, and the onboard Gigabit Ethernet work reliably.
My plan would be to start with two SATA drives and use the board as a basic file and backup server rather than run heavy applications.
If someone has tested FygoOS on a ROCKPro64, which image, U-Boot file, SATA controller, and power supply did you use? Smile
Brick Logical Extensible Gizmo Organizing RockPro64 Enclosure hoarfrosty 0 3,279 08-06-2023, 09:32 PM
Last Post: hoarfrosty
  RockPro64 programing GPIO by Rust yanagawa3 0 5,027 11-24-2021, 08:43 PM
Last Post: yanagawa3
Photo RockPro64 programing GPIO, I2C,UART and SPI madhuks 3 11,840 08-06-2020, 09:07 AM
Last Post: Gienek
  RockPro64 as PATA/SATA bridge? Count Omega 1 7,601 12-07-2019, 02:25 PM
Last Post: Count Omega
Question HOW TO fix Wifi on RockPro64 - Recalbox OS and upload roms on SSD External Gouki 6 17,034 08-25-2019, 05:13 AM
Last Post: Gouki
  ROCKPRO64 for SCRAPING Ulthor_31 4 12,449 08-01-2019, 05:19 AM
Last Post: Ulthor_31
  RockPro64 as PVR/DVR bm_00 1 6,370 02-27-2019, 04:46 AM
Last Post: mabs
