Anyone using a Pinebook Pro for browser-based coding instead of cloud IDEs?
I have a Pinebook Pro that I mostly use for writing and light terminal work, and I'm trying to figure out whether I can make it my main machine for small web projects. The browser-based IDEs I used to rely on feel sluggish on the Pinebook's hardware, and I'd rather keep things local anyway. I'm considering setting up a lightweight local toolchain and just using the browser for testing, but I'm unsure about RAM limits when running a dev server and a browser with several tabs at once. I also don't know how well the ARM build handles Node-based tooling these days. I have no experience with the alternatives people mention for app building, so I don't want to commit to a workflow that stalls on this device. Has anyone here settled on a setup for the Pinebook Pro that stays responsive? Which tools did you land on, and what would you avoid?
Update after looking around more - Best Replit Alternatives (2026) kept coming up while I was checking for lighter browser options. Still not sure any of them would help much with RAM when a dev server and several tabs are open on the Pinebook.
I went the local route on my Pinebook Pro for the same reason — a lightweight editor and a local dev server kept things snappy, while anything browser-heavy with a dozen tabs open would crawl. I keep the browser to one tab for testing and do the actual editing locally. My dad's old ThinkPad handles the heavy stuff; the Pinebook is for writing and small fixes on the couch.
I went through the same thing on a different ARM laptop last year. Browser IDEs felt fine until the third tab plus a dev server, and then everything crawled. What actually worked for me was keeping the editor local, just a light editor with a terminal beside it, and only opening the browser to check the page. Node builds still hurt, though. I ended up skipping the heavier bundlers and serving plain files with a tiny static server when I could. It is not glamorous, but the machine stays usable and I stopped losing work to frozen tabs. I would avoid running the full toolchain in the browser if you can help it.
  Selling Pinebook Pro, PineNote and PineTab-V arw 3 2,488 10-29-2026, 03:14 PM
Last Post: arw
  Could Someone Give Advice on Optimising Pinebook Pro for Software Development? Octaviah 0 2,772 08-23-2024, 12:45 PM
Last Post: Octaviah
  [Pinebook Pro] Where to buy a new TFT and how to replace it? openbsd98324 2 3,751 07-23-2024, 07:14 AM
  [Article] Coding Ox64 BL808 SBC the Drag-n-Drop Way lupyuen 3 4,934 04-02-2024, 07:38 AM
Last Post: Noahstorey
  [Article] Emulate Ox64 BL808 in the Web Browser: Experiments with TinyEMU lupyuen 3 4,643 02-17-2024, 06:53 PM
  New Phone, Laptop and Tablet based on RK3588 Zotax 6 15,250 09-28-2023, 12:43 AM
Last Post: faultyforelimb
  Pinebook Pro with RK3588? tantamount 28 30,615 07-13-2023, 04:06 PM
  The power of the Star64 vs Pinebook Pro/RockPro64 Starfall 1 3,863 04-17-2023, 05:00 AM
Last Post: lkoini
  Pine64 3D printer based on Positron V3? poVoq 0 2,838 05-21-2022, 11:50 AM
Last Post: poVoq
  Could an arm based pine 64 smaller than expected to go with the pinebook zanewiller 1 4,081 04-16-2022, 07:17 AM
Last Post: jiyong
