USB on Quartz64 Zero
I apologize if this post is against the rules.  I have some Quartz64 Zero boards and no matter what Linux image I use the USB port doesn't work.  The Android 13 sdcard image does have USB but the OS is unstable.  Does anyone know how to bring the USB port up?  I have console access via cp2102.
Which Linux image did you use? There does not seem to be any for the Quartz64 Zero, and the Quartz64 Model A device tree seems to have the USB issues on the Zero. I wanted to look into the device tree of the Android 13 image, but couldn't find sources, and am not keen to download the full 111 GiB SDK: https://forum.pine64.org/showthread.php?tid=20326
So if anyone knows whether/where there are browsable PINE64 Android sources, or has the SDK at hand to post the Quartz64 Zero device tree here, I might be able to derive one that works (including USB) with mainline Linux.
  DietPi OS for Quartz64 MichaIng 48 59,958 07-22-2026, 01:52 PM
Last Post: MichaIng
  irradium (based on crux linux) Quartz64 riscv64, aarch64 mara 8 18,404 03-07-2026, 04:21 PM
  How does CPU frequency scaling work on the Quartz64 pugzarecute 0 2,446 07-30-2025, 07:19 AM
Last Post: pugzarecute
  Armbian and LibreELEC and AltLinux for Quartz64 balbes150 152 183,945 03-23-2025, 01:10 AM
Last Post: balbes150
  slarm64 (unofficial slackware) Quartz64 RK3566 (aarch64) mara 56 90,542 10-17-2023, 10:55 AM
  quartz64-a - on-board SATA port problems manning 2 5,738 09-14-2023, 04:22 PM
Last Post: manning
  How the reset Quartz64-b onboard memory (emmc) beepy 2 4,622 07-20-2023, 10:44 PM
Last Post: beepy
  crux-arm Quartz64 RK3566 (aarch64) mara 5 11,159 10-29-2022, 06:55 AM
  Ov5647 camera attached via csi to Quartz64 /Soquartz Randomuser 0 4,145 07-21-2022, 01:08 PM
Last Post: Randomuser
  Armbian on Quartz64 dieselnutjob 34 57,601 03-17-2022, 06:29 AM
